1992 throttle position sensor failing, again!
Old Feb 19, 2010 | 01:03 AM
prairie pirate's Avatar
had 62,000kms on my truck (last summer) when i noticed it starting to slip out of high gear(automatic). assumed the worst, figgered tranny slipping, got tranny flush done, still slipped. dealership diagnosed the TPS faulty. put in new one, $660.00 cdn, worked great. put on 2000 more kms, started doing it again. first thought it was gelling fuel, (got cold as hell up here) still had some summer fuel in. ran fuel out, still does it.
PROBLEM: sometimes (but not all the time) when it gets warm it starts dropping out of high gear, revving up and then shifting up eventually.
SOLUTION: stomp pedal to floor, take it up to 115+ kms/hr and keep it there, it usually stays then. drop below 110 and it drops out of gear.
i suppose it is possible that the new tps is faulty, but could there be something else causing it? anyone else have this trouble? am taking it to dealership tomorrow and am probably gonna get hosed on labour as they try to diagnose this one... HELP!
Old Feb 19, 2010 | 12:58 PM
2stroke's Avatar
The TPS is adjustable.
Old Feb 19, 2010 | 06:00 PM
Check the sticky in the 1st gen forum for info on how to adjust the TPS. If that does not fix it, there are other options besides another $250 TPS.
Old Feb 20, 2010 | 05:49 AM
AlpineRAM's Avatar
On a 2nd gen I would say that you have some electrical noise.
Might be worthwhile to look at your alternator brushes and your ground connections.
HTH
AlpineRAM
buckshot
Dec 29, 2003 02:24 PM
cavemanscummins
Dec 22, 2003 08:15 PM
KATOOM
Dec 12, 2003 01:20 PM
twhite
Oct 31, 2003 10:50 AM
tishmael
13
Dec 2, 2002 12:39 PM
