Keeps blowing headlight
Old Feb 16, 2010 | 07:02 AM
BigDiesels's Avatar
Anyone had the experience or know why my 06 2500 would keep blowing the passenger headlight? I've been through 5 already on the right side, none on the left. Doesn't matter if it's the stock halogen or the Silverstar. I haven't put a meter on it yet, but I suspect over voltage. Is there a regulator or something in this circuit?
Thanks.
Old Feb 16, 2010 | 09:57 AM
infidel's Avatar
Does the lens have a leak or crack that's allowing water inside?
Old Feb 16, 2010 | 12:12 PM
BigDiesels's Avatar
I don't think so...everything is dry when I replace the bulb. I should also say that I am careful not to touch the glass on the bulb when replacing.
Old Feb 16, 2010 | 03:11 PM
Mexstan's Avatar
Is there any part of the headlamp assembly that is a bit loose that could cause the bulb to shake around? (vibrate) I can't see an over voltage in on part of the circuit. If that happens it will tend to be an over voltage everywhere. My guess is that eventually you will discover that it is excessive movement of the bulb that is causing the problem.
Old Feb 17, 2010 | 09:09 AM
johnh's Avatar
Thanks.
bad ground??
Old Feb 18, 2010 | 11:21 AM
kloppk's Avatar
Originally Posted by johnh
bad ground??
Agree.
An intermittant connection will kill bulbs.
Had it happen on a car once. Kept burning out 1 headlight until I found the loose connection.
Old Feb 19, 2010 | 10:21 AM
BigDiesels's Avatar
I will try to look at the wiring this weekend (hopefully). I'm pretty sure it's not vibration, as I changed the bulb this morning, and everything is tight, and the bulb mount is actually isolated by a grommet type thing, so even really rough roads (which I do drive on) shouldn't really affect it too much. Also, the filament isnt broken, like I would expect from vibration.
Old Feb 22, 2010 | 06:46 AM
BigDiesels's Avatar
Turns out it is a bad connection at the plug. The bulbs are actually good, but the contact is weak with the bulb pins. Now gotta see how much for the female connector half...
cginwyo
Jul 18, 2007 09:19 PM
WS6HUMMER
Mar 10, 2006 10:52 AM
cuda72
Oct 19, 2005 06:02 PM
storx
Aug 24, 2005 07:37 AM
Cumminsdude
Jul 12, 2003 08:39 AM
