Why do diesels have more torque than gassers?
Re: Why do diesels have more torque than gassers?
Originally posted by iwantaCUMMINS
Just wondering.
Just wondering.
Longer stroke with the same horsepower equals more torque.
I always wondered when I first started as well.
Saw gassers advertised as 300 HP and 300 Torque.
Whoo, hoooo!
Same HP Diesel gets 600 Torque, and at lower rpm.
phox
It also has to do w/ the compression in a diesel...a gasser has like 8:1-10:1 and a diesel has 17:1 (just ballpark figures). More compression = more energy released. And the turbo will give you more torque too.
Just a few short years ago the v-10 was king in the torque department in the Dodge truck line. Gobs of torque at a low rpm. Now the diesel is king, but the mileage seems to be slipping down as the torque wars go up. I think we are on the down hill curve on the diminishing returns graph on power vs. economy.
"I think we are on the down hill curve on the diminishing returns graph on power vs. economy."
I've never thought of it that way...interesting, but very true. The big rigs only get somewhere between 5-9 mpg when hauling on the highway. But I guess when you think about it, if you had a gasser that could possibly haul as much weight as a big rig they'd be getting around 2-5 mpg.
When you think about your average Sub-urban with a big block getting 10 MPG at maybe, 7,000 lbs., 6 MPG moving 80,000 LBS. is pretty reasonable, dontcha know! Also, on the torque question, diesels have a longer burn time, as in positive cylinder pressure for more degrees of crankshaft rotation. Another plus that helps with the longer stroke. Jim
It really doesn't make sense to me when you consider that even though an individual rig will make less smog what about the additional emissions produced by the extra amount fuel that must be delivered by truck, pipeline, etc?
The lose of mileage is due to EPA regs.
Their process makes an engine use more fuel to reduce what comes out of the tail pipe. NEVER understood this idea.
To save the world we must use more??
If you are old enough to remember carberators, you can see whay they did.
I had a 71 chevy, 2bbl cab 350 , from factory it would at best get 14 on the highway.
I removed the heads and replace them with smaller chamber heads for a raise in compression and dropped a smooth 4 bbl carb. guess what it ran smoother and could get 21 on the highway. Just a little humor, but the world is still here!!!
They are doing similar things to the Diesel engine.
The old 12 valves could be tuned to get high 20's for mileage.
Try that with anything made today!!!
End of rant!!
End of rant!!
I'm sure the compression ratio is a factor too.
End of rant!!
End of rant!!
Climbing some of the passes in the Northwest, you could see the smoke trail for miles back down the pull as you went up. No air either, prop the door open with your foot for a little more air at 5 mph going up. Going down was worse, you knew what you were doing or you died. Several times with the little engines I smoked the brakes at the high speed of 10 mph or so and stopped at the bottom glad to be alive. A short one that would weed out the inexperienced was Fancy Pass. You were always glad to get that over with. Technology will demand more mileage and power.
The diesel mileage keeps getting better and better and the comfort and safety is better and better.
SOhappy
09-08-2009 02:56 PM
erics76
09-17-2007 09:12 AM
