Espar, Proheat, Webasto..........
Old Oct 23, 2008 | 09:25 PM
  #46
1-5-3-6-2-4's Avatar
Oh very good to hear......I really should open my boxes and read the paperwork with mine I hope its that easy.
Old Oct 24, 2008 | 01:26 AM
  #47
winkdemon's Avatar
its super easy luke , i have done 6 of them at work plug and play
Old Oct 24, 2008 | 11:50 AM
  #48
Lil Dog's Avatar
The harness out of the Espar on mine was a blank plug end and you had to put in the pins. There is a blue wire in the #3 position on the heater and a rubber stopper in the male end of the plug harness. I have to put the pin/wire into the harness then run it to the engine bay. With the 97, I don't know if there is a relay in the system for blower power, just a fuse. so I have to put in the NO/NC relay.
Old Oct 27, 2008 | 08:57 PM
  #49
dieselman2300's Avatar
I got my D5 from here http://lubricationspecialist.com/front/index.aspx for I want to say $1200 with the 7 day timer.
I got it last winter and its still sitting in the box in my garage LOL! I have a week off this week and I think I will be installing it.
Old Oct 31, 2008 | 12:45 PM
  #50
ScottN's Avatar
So a couple days ago I rewired my Autostart to be a remote start for the heater. Ideal!
Old Oct 31, 2008 | 02:50 PM
  #51
Diesel Dave2's Avatar
Pickin on the wrong admin...
Originally Posted by 1-5-3-6-2-4
I did get the D5 and timer, they're in the garage as we speak.
Lildog.. where does that signalwire come off of, the timer or the heater harness? Is it on the schematic?
i haven't got it out of the box yet, that will certainly be a must do for me when it gets installed.
If you don't mind me asking...What was the total cost including GST??Did it come around $1200??Are there two version of the D5??One a hydronic D5 or is that the same as a D5....
Old Oct 31, 2008 | 07:29 PM
  #52
winkdemon's Avatar
if u go to polar inc in calgary , the heater is 899.00 and the timer is 300 . plus tax , for a d5 witch is a hydronic
Old Oct 31, 2008 | 08:13 PM
  #53
Dr. Evil's Avatar
Dave - they are ALL Hydronic Coolant Heaters - Espar - D4, D5, Webasto Blue heat:
http://www.espar.com/documents/hydronic4_5.pdf
Old Oct 31, 2008 | 10:46 PM
  #54
Festus's Avatar
OK...more questions.
Where does this mount exactly? I may have an issue with my Air Dog that's mounted on the driver's side frame rail - hopefully I can get it in front or behind.
Can it be mounted on the passenger side if absolutely necessary and run the fuel line across?
Old Nov 1, 2008 | 02:19 AM
  #55
bigd450's Avatar
I mounted mine on the skid plate right behind my transfer case. Other than running the coolant lines its a decent spot it stays nice and protected and I havent had a problem so far.
Old Nov 1, 2008 | 03:00 AM
  #56
chrigu's Avatar
hi guys
i have order he kit from espar.
now my questions: about fuel conection on 03 truck with tank mounted or not for make connection?
chris
Old Nov 1, 2008 | 07:26 PM
  #57
Tate's Avatar
Mine is on the drivers frame rail right at the front of the cab. I plan on putting it in the same place on the 12v, pending driveshaft interference. Did I mention I hate 4x4s?
Old Nov 2, 2008 | 12:11 AM
  #58
han solo's Avatar
The webasto install kit for 03/08 trucks mount the heater in front of the right steer tire, behind the plastic inner fender. Which makes a short run for the coolant hoses. Yes I have taken the training coarses for these heaters, the small heaters are to be mounted as close as possible to the engine. The webasto blue heat kit comes with a stand pipe that goes into the fuel tank sender housing.
Old Nov 3, 2008 | 10:35 AM
  #59
So what D5 Espar is worth $1900, if they seem to fall is the $1300 range with timer?
Old Nov 3, 2008 | 12:25 PM
  #60
Dr. Evil's Avatar
English please...
