Espar, Proheat, Webasto..........
Old Nov 3, 2008 | 12:57 PM
  #61
Diesel Dave2's Avatar
Pickin on the wrong admin...
Me don't speak it, the english....I found in the bargin finder a D5 Espar.I called the guy and he said he paid $1900 for it and wants $1300..The way it looks there is only one D5 espar and they run about $1300 with timer..New..
Old Nov 3, 2008 | 01:22 PM
  #62
winkdemon's Avatar
if he bought it must places he would of paid 1900 for it . just have to shop around .. and people don't
Old Nov 3, 2008 | 02:03 PM
  #63
Lil Dog's Avatar
If you're looking at my price, it included an 8 hour install..
For the time it takes, the D5 kit I had came with the dip tube for the tank. I would go that route the next time instead of the factory spigot on mine.
Old Nov 3, 2008 | 02:05 PM
  #64
Your price I understand...That including labour...This is just the cost of the D5...Got to shop around...
Old Nov 5, 2008 | 06:05 PM
  #65
Tate's Avatar
My D5 was $1900 from Cummins two years ago. I tried shopping around Calgary, wasn't much I could find at the time. That included the draw straw and timer. There are also air heaters (Airtronic) heaters from Espar. I wanted mine to preheat the engine, the cab was just a nice bonus. If you're just looking for a warm cab, an Airtronic heater could be something to look into.
Jason, whats wrong with going to the factory pickup for the install? I'm planning on switching my heater to the 12v now that I'm home, but I don't want to lift the beds off of both trucks, especially since the 12v has the gooseneck hitch in it.
Old Nov 6, 2008 | 09:26 AM
  #66
Festus's Avatar
So, is $1260 a good price for the D5, Dodge plug & play install kit, and 7-day timer? No installation - do it myself.
Old Nov 6, 2008 | 09:30 AM
  #67
Mlucas's Avatar
Yea-1260 is a good price IMO
Old Nov 6, 2008 | 11:33 PM
  #68
Lil Dog's Avatar
I am having a heck of a time getting an air tight seal to the tank. With the swedging I had to do to go from the 1/4 line on the pump to the 5/16??? size on the spigot, I get air in it after every shutdown. Makes it hard to get the heater started first crack. I need to get under there again and re-check all my connections. The dip tube just eliminates all that junk..
Old Nov 7, 2008 | 11:41 AM
  #69
DODGER BOMBER's Avatar
Can you PM me with were u got that price. Im looking for one this winter. Was gonna last winter but i think i might need one out here in sask.
Old Nov 7, 2008 | 12:38 PM
  #70
Patriot1's Avatar
Can i make a suggestion on the heat here? I have 3 heaters on my truck. Now what i did was i got the newer cummins 8.3 block heater it is 3/4 of an inch. Now all the 5.9 have are 1/2 pipe thread. Now you can use the lower part of your block like i did and go from 1/2 to 1 inch pipe and back down to 3/4. This is a 750 watt heater i put in the lower water housing and i leave it in over nite and that thing heats up everything nice for the engine including the oil. Then i have a davco fuel filter as well and that is a 100 watt fuel heating element in it as well. But it has a manifold inside that you plumb to your water line as well so the fuel is at coolant temp. Then i took a Katz heater and it is 300 watts and i stuck it to my gas tank and it is magnetic heater . Now mind you all you guys have plastic tanks i don't but i also have a 44 gallon tank in my truck as well. I no when i have 10 degree morning it starts right up and i have removed the heater grid delete. So if this helps and it's really cold by you guys you might have some luck with it. Now i do plan on moving back up north into the upsate portion of NY or PA by the end of the year. So i hope the fruits of my labor won't go to waste.
Old Nov 7, 2008 | 12:42 PM
  #71
ccmckee's Avatar
That's all fine and dandy Patriot if you have some place to plug them in. Most of these are working in remote locations and have no power avavilable.
Old Nov 7, 2008 | 03:16 PM
  #72
Festus's Avatar
PM sent.....(add more characters for not long enough message)
Old Nov 7, 2008 | 05:19 PM
  #73
Tate's Avatar
And no worry of breakers tripping either. Or driving away with the cord still plugged in to the truck. I've never done that myself, but I do remember one of the admins talking about doing that, and he was in Guam!
Kiel, when's the next time you're coming back to the Calgary area? PM me your cell number if its different from your old one.
Old Nov 7, 2008 | 05:31 PM
  #74
Me too....could you send me the same PM....
Old Nov 7, 2008 | 07:52 PM
  #75
Festus's Avatar
PM sent...............................
