what twins
what twins
what would be a good setup for me...i tow regularly about 10k lbs and want to be able to pull that with 120hp sticks with little egt worries. I do drag race the truck and will be pullin this summer
^^^search^^^
There are thousands of threads on this. Do some searching, talk to Nathan @ MPI, or Tim B at TRE and go from there. Trust me, I am in your shoes and have seen the same response. Do some research, it is so much better when you make up your mind.
You could go with the stocker over either a S400 or a Gt42. I went with my Phat Shaft 62/14 over a GT42 because it's supposed to spool faster than a S400 but flow close to the same. Approx 96 lbs/min. For me, the ability to tow was first and foremost with a cooler EGT in the 1/4 a close second. Call Nathan and tell him what your looking to do.
Another plus for the GT42 is that it's waste gated giving you better control over tuning.
Good luck!
Angelo
Good luck!
Angelo
I will be going with Nathan's twins as soon as i can afford it so heres another vote for MPI. And your truck looks awesome. Those are the wheels i want, badly.
dodgediesel
17
04-05-2011 11:21 AM
Stock 02
28
09-24-2006 11:09 AM
stlsparky
11-21-2005 10:02 PM
