Smarty Jr setting?
Old Oct 22, 2011 | 08:54 PM
  #61
mattwv88's Avatar
Well after trying several different setting it seems that my truck likes SW2 TQ2 TM4 for MPG. I check it by hand at each fill up and I got 17.8 with these setting.
Old Oct 27, 2011 | 12:18 PM
  #62
sojoe's Avatar
KEEP ON "BEATING THE TOPIC".....................................Always something to learn
THANKS to AH614 for all the input--I shall continue to listen.............
Old Oct 27, 2011 | 01:20 PM
  #63
InfernoMega06's Avatar
Finished my first full tank a few days ago. 18.0 mph by hand. That was about 40% city/60% highway. I also put my foot in it several times. My mpgs will go up once the new "fun factor" goes away a little. My setting is SW3 TM4 TQ 2.
Old Oct 27, 2011 | 05:04 PM
  #64
mattwv88's Avatar
Well I am going to beat this topic some more. I just filled up and I only got 13.3MPG!!!!! WTH? lol. I got a flow pro turbo back 4 inch ehaust at the start of this tank and I thought that was suppose to help it. I was useing SW1 TQ2 TM4.
Old Oct 27, 2011 | 05:10 PM
  #65
mattwv88's Avatar
Does the TQ setting alone affect MPG at all?
Old Oct 27, 2011 | 06:48 PM
  #66
PoorMansCat's Avatar
Pulled one of the heaviest loads I have EVER pulled yesterday, about 20K... The truck has never felt this good. Was able to pull hills on Interstate passing 18 wheelers.. Wasn't pushing the truck hard, the truck is just "woke up" on this setting...
I wonder if some of these different results with the same settings has alot to do with different driving styles... ??
Old Oct 30, 2011 | 06:42 PM
  #67
mattwv88's Avatar
Yes I thought that it MUST be my driving as well but I drove really easy after this past fill up and I just checked it (by hand ofcourse) and I ONLY GOT 11.8MPG! WOW!! I can`t handle this. I checked my air filter and its clean. I am changeing from the SW2 TQ2 TM4 to SW1 TQ Def TM Def and see if that helps at all. I can`t be dumping money into fuel like this.
Old Oct 30, 2011 | 07:28 PM
  #68
Not sure if it matters, but my truck has 3:73 gears, is running stock suspension, and stock tires/wheels..
Old Oct 30, 2011 | 08:43 PM
  #69
slickr1's Avatar
I just pulled a 18' v nose trailer from PA to Idaho. The trailer weighed about 6k loaded and I got 11 mpg.
Running my jr on sw2, did not use the tow haul, but might give it a try on the way home. And by the way the elk hunting sucks.....
Old Oct 31, 2011 | 08:59 AM
  #70
AH64ID's Avatar
Seems hit or miss for guys this year. I didn't go due to some Military training, but my Dad an Bro were up near Salmon and buried in elk. They tagged out (3 bulls) in a few days and were gone early this year. Other camps I have talked to have not seen much.
Old Oct 31, 2011 | 12:56 PM
  #71
slickr1's Avatar
AH. shot you a pm.
Old Nov 5, 2011 | 12:31 PM
  #72
Lost Lake's Avatar
Who told you an exhaust would help? A salesman?
There have been so many posts about exhausts on this forum it isn't hard to find one that would help you. I can sum them up this way: When the exhaust is removed completely and the truck is put on a dyno, no horsepower gains are noted unless you are putting out 500 - 600 hp. Turbos love a free flowing exhaust, but stock is perfectly adequate. You won't gain power or mileage with an exhaust, or an intake for that matter. Maybe I just saved you some money there.
Old Nov 5, 2011 | 11:31 PM
  #73
mattwv88's Avatar
Thanks for the info my friend. I will not be spending the money for an intake then. My mechanic told me that an exhaust kit would help my MPG and my over all HP. Lesson learned here. I do not regret the exhaust though. I LOVE the sound of it and it is a stainless kit and will last as long as I own the truck. The sound alone was worth the money to me. Thanks for the reply. I switched to SW1 with Def on TQ and TM. I have yet to fill up to check my MPG with these setting. I will see how it does. If anyone has any idea`s as to why MPG would drop over a few week period like it has please let me know. I am not looking to have awesome MPG just something half way good. I would be happy with something in the 17-18 range.
Old Nov 6, 2011 | 09:46 AM
  #74
What state are you in?.. I wonder if you are on winter fuel? and is the truck stock other than the Jr? and oversized tires, levelling kit, lift?
Old Nov 6, 2011 | 05:07 PM
  #75
Lost Lake's Avatar
It could be your torque converter slipping... My mileage went down before the converter started acting up.
