Smarty Jr setting?
#76
I live in WV. I am unsure if we are on winter fuel or not.
Other than than the tires, lift and smarty I also have a 4 inch turbo back exhuast.
I sure hope it is not the TQ converter.
The MPG is alittle better but still not like it was before.
Sorry it took me so long to get back to you guys. I just got back from a hunting trip in IN. (I came back without a deer too)
#77
So far for me it's a love hate feel on lastest version. Love the minimal smoke. But all and all SW is alot differant then prior versions and take more to dial in hence the hate. But thats my feel. Sw3 TM4 TQ2 use to be alot more wicked then now but is still nice but differant for sure. I do notice sw2 TQ1 TM2 is alot stronger through power band then SW2 TQ1 TM4 as it is slow to engage. Mileage seems easier to get then before but can easily fall off just as quick. Also I think my trans is ALOT more sensitive to this version then any other for sure. So still playing good or bad still Love Marcos way of doing things.
#78
If you can keep your foot out of it you will get the best economy on SW3 TM4, TQ4 and PoD 80 will keep the trans happier.
If you can't keep your foot out of it run SW1 TM4 TQ4 PoD 90.
Also, running TM4 don't extend your oil change intervals beyond 7.5K and be sure to run a stratapore oil filter or better.
#79
PoD isn't quite linear in its power reduction. With PoD at 80 you have 80% of throttle available, hp doesn't equal 1% per TPS so it's not a cut and dried reduction. Your probably in the mid 300's on power? I am at PoD 70 right now and am probably at or slightly lower than stock power when I am WOT, but at lower power levels I am higher.
Your clutch will tell you when your making too much power.
I would get boost and EGT gauges installed.
#80
#82
We've been running it on SW-3, TM-D, TQ-D. He drives it easy with very rare short WOT bursts. But you're suggesting SW-1 or 2, TM-4, TQ-4 and PoD-80, correct?
#85
THANKS! Now I think I understand how POD works. Everything feels the same up to WOT. In other words with my setting, it would drive the same up to whatever number put into POD.
#89
Long story short, sold my smarty jr awhile ago but recently got another. It has version 5.08 and want to update it to the latest. Is there a way I can keep 5.08 on the computer and go back if desired?
