Smarty Jr setting?
Old Oct 13, 2011 | 03:28 PM
  #46
cstewart's Avatar
From a stop, she'll smoke pretty good in SW2, TM4...
I do agree though, the smoke is considerably lower when at cruising speed and slightly roll in the throttle. Used to get a good bit of smoke when i'd do this. But now not so much!
Old Oct 13, 2011 | 06:50 PM
  #47
MTC's Avatar
MTC
I played around with it today and I really like the power delivery compared to v5.08...and the smoke is almost nonexistant...tried to make it smoke, but couldnt get more than a haze.
Old Oct 13, 2011 | 07:45 PM
  #48
wiskeyVI's Avatar
I was using 2/2.
I went to default towing and that was more like it!
I went to 3/D/D today for my 12 HR drive tomorrow to see how it runs.
Old Oct 13, 2011 | 08:26 PM
  #49
AH64ID's Avatar
SW2/2/2 is the same as SW2/D/D.
Old Oct 15, 2011 | 03:25 PM
  #50
PoorMansCat's Avatar
So how is economy for towing???
Old Oct 15, 2011 | 03:34 PM
  #51
justen920's Avatar
I like my settings, and I need to do the update but I am a little hesitant for change. I leave it the same for towing and daily driving.
Old Oct 15, 2011 | 07:30 PM
  #52
wiskeyVI's Avatar
AH64ID,
I thought they were the same as well. But the truck seems to drive differant.
I set it on SW3/D/D before my trip and it drove like great and milage went up as well (according to the OH)
Thinking back on it, I ay have had it set differant as I was plang around with differant setting.
I'll leave it as is for now untill the weather gets bad.
Old Oct 15, 2011 | 07:45 PM
  #53
mtman86's Avatar
Smile
Originally Posted by MTC
I really like v21, but I miss being able to black out tailgaters like I could with the 5.08...Dont get me wrong, Im not one of those fellers that black out every intersection, but I cant stand a tailgater...and now I cant make them back off
Wire up a set of aux. back-up lights on a separate switch.......aircraft landing gear lights work great. Quick flick and it'll look like a flash went off in your rear view mirror.
Old Oct 16, 2011 | 09:30 AM
  #54
MTC's Avatar
MTC
LOL...Im going to look into that
Old Oct 17, 2011 | 10:31 AM
  #55
AH64ID's Avatar
It's excellent. It's all my dad runs, and he tows pretty heavy, and all I ran for the first 50K miles with the Jr. Honestly under 90% of towing scenario's I don't see the difference in towing on SW1 vs SW3.
Old Oct 17, 2011 | 07:45 PM
  #56
I really like the Economy setting.... it pulls really strong in the midrange.. whichs is where I have always felt this truck was the weakest. But, i wasn't sure about how it was for pulling heavy... the egt seems to run cooler unloaded.... Will be pulling with it Thursday, gonna leave the programming in it, in the past, i have put it back to stock when pulling..
Old Oct 18, 2011 | 08:08 AM
  #57
AH64ID's Avatar
Towing is the #1 reason I bought the Smarty Jr. I have never understood removing it to tow. The stock timing is not programmed for economy/power/performance. SW1 is timing only, and shows what the motor can really do!
Old Oct 18, 2011 | 07:51 PM
  #58
kdavis80s's Avatar
SW is softare 1= economy, 2 = towing, 3 = performance.
As for EGT's your stock EGT's were in the 1450° range, but if you go that hot with added timing you will melt something.
Here is what I use...
Smarty Jr rule of thumb for 04.5-07 5.9's.
TM1: 1400 max cont, 1450 momentary
TM2: 1300 max cont, 1350 momentary
TM3: 1350 max cont, 1400 momentary
TM4: 1250 max cont, 1300 momentary
thanks for the info
Old Oct 19, 2011 | 09:57 PM
  #59
DodgeChallenger's Avatar
I don't know folks but I run SW2 and defaults for Tq and timing. I get an honest 16mpg imperial towing a 15000lb 5th wheel. Unloaded it accelerates like never before and gets 25mpg or 21usmpg but thats at about 60-65mph max. What am I doing different. You are not going to get VW diesel mileage out of these things and every time you floor it put 2 or 3c in a jar on the dash to see how much money you are throwing out the exhaust. Anywhere from 18-21mpgus is probably pretty good in engine setup and your individual driving habits.
Old Oct 20, 2011 | 09:25 PM
  #60
truck felt really good pulling today... I think the camper is right around the 8800-9200lb range... Didnt have to push the throttle hard, egt was great... its really is amazing what happens when you remove the government (EPA) from the equasion..
