Smarty Catcher Question Marco-Bob
Ok, so now that the Revo is out it leaves me wondering a few things about the catcher levels. This is likely a question for Marco or Bob.
Question is this: Does the fuel mapping or any other changes happen between software levels 1-9 when you've manually set all the other options.
Example: Say you set all the available options manually. TQM stock, Injection aftermarket, wastegate off, ETC ETC. Now will you experience other changes when moving between the catcher levels or is the mapping the same, but normally just with different TQM and other settings, etc.
Thanks for the help!
Yes. It's on Mad's website.
At the end of the items list, Smarty will store your selections in its memory. In this way, your preferred
selections will be applied every time you program your truck.
As a simple example, if you set the Speed-limiter to “100”, Smarty will always use that value for all
ECM updates. That’s, until you change the value again or return Smarty back to stock.
That doesn't really answer my question though. I'm asking if there are other details that are changing between the catcher levels even when all the available options have been set manually. For instance, fuel mapping, etc.
molalla1ton
18
11-17-2007 07:32 AM
tritont
21
11-15-2007 02:30 PM
HeberRam
11-18-2006 01:22 PM
jonesm8
19
10-21-2006 03:07 AM
Charlie8301
28
11-14-2005 11:26 PM
