SLC Transmission
Adding more billet or did you have a problem with the Suncoast?
I know Gillett's Diesel uses Intermountain Transmission for their more serious tranny work. Like Mark said though, I would go with Terry up at Moonlight Diesel.
Eratic Shifting
It doesn't seem healthy. I has started to shift erratically between first and send and not seem to want to grab...under light throttle. I know this is something that is common, however it just started after 10K miles so I think something might be wrong. I want a good tyranny guy to look at it.
any trans shop will tell you they can do this and that but moonlight builds true High HP trannys....but if you go to the local 5 star transmission or AAMCO you wont be happy..
just my .02
I went to J&g transmission to have mine built with all billet parts and heavy duty clutches etc. Anyone can build a high performance tranny. It just depends on what is put into one. They are in murray area and will give a 3 year warranty to boot. They have built trannys for sledpullers before also.
Moonlight diesel ????? when was the last time one of there race trucks had over a hundred passes on one tranny and well Gillet or Guns & Roses is a whole other story. Maybe a Wide Open has an idea or hey even those one guys over at Industrial Injection might have one. But I also heard some guy at Best Buy is doin trannies on the side it will save you 500$
routerguy99
03-26-2014 08:19 PM
nate_88
13
09-11-2009 08:04 PM
