SLC need Mechanic for Front Brake Sensor
Old Mar 25, 2014 | 03:15 PM
routerguy99's Avatar
I am in SLC I would like to know a good place to take my truck in for a Replacement ABS front Sensor ?
does anyone know a good place to take it.
Chris
Old Mar 26, 2014 | 12:21 PM
bhuffstutter's Avatar
I recommend trying to replace it yourself. Its pretty easy with just a couple of hand tools. You should be able to get the sensor at any parts store...
Old Mar 26, 2014 | 01:33 PM
railroaderone's Avatar
The Abs sensor is easy to replace you will need the following tools
A jack
Set of Allen wrenches
Tools to remove the tire
Remove the tire from the truck the abs sensor is located in the hub you don't have I remove the caliper to get to it.
Remove the Allen head bolt that holds it down give it a slight twist and pull it out.
Old Mar 26, 2014 | 04:38 PM
Dr.Dizzle's Avatar
Originally Posted by railroaderone
The Abs sensor is easy to replace you will need the following tools A jack Set of Allen wrenches Tools to remove the tire Remove the tire from the truck the abs sensor is located in the hub you don't have I remove the caliper to get to it. Remove the Allen head bolt that holds it down give it a slight twist and pull it out.
Think it's safe to crawl under a vehicle while it's supported by a jack? Umm no!
It's always a best practice to support the weight of the vehicle with a pair of quality (weight rated) jack stands.
Old Mar 26, 2014 | 08:19 PM
Actualy dr you won't be under it throw the tire under it to keep it off legs if it falls
Rally2
May 1, 2010 12:27 AM
nate_88
13
Sep 11, 2009 08:04 PM
BuildingBoost
Aug 2, 2007 12:55 PM
Dodge359
Jul 5, 2007 06:04 PM
EricBu12
Apr 20, 2003 09:52 AM
