Is Fass the answer?
With the Smarty set on SW#3 my fuel pressure drops fast, right down to 0-1 under heavy acceleration, I believe the truck is starving for fuel, would a FASS cure this problem? If so which one should I get? Or is there something else I should look into first (mod CP3?)...mod's listed in sig.
TIA,...B
On a side note I tried the seach function first but it doesn't seem to be working for me
TIA,...B
I like the GDP Walbro Competition Kit. The model number is GFS-392 on glacierdieselpower.com; that's the kit I have on my truck and so far so good. I plan to get their MK2 filter system real shortly. The Walbro pump is quieter and pumps more fuel to your CP3 than the FASS. Both are good kits, I just prefer the Walbro kit.
I just like the glacier setup better. I think it makes for a cleaner installation because the whole assembly is smaller and you can get the MK2 kit for filtering. It mounts underneath the intake horn for easy filter changes and comes with a trick looking bracket. That's just my opinion though. Like I said, either system will perform it's job......
