24 valve to 12 valve conversion
Old May 15, 2008 | 10:36 AM
DeerHunter812's Avatar
I Have A 1999 Dodge Ram 2500 Cummins Turbo 24 Valve 5 Speed 5.9L Truck That I Have Switched With A 1994 12valve Diesel Engine. I Need To Know Either Two Things. Does Anyone Know How To Hook Up The 1994 Wiring Harness(12 V) To The 1999 Ecm Unit? Will the PCM talk correctly to the BCM to get the tachometer to work? Any help would be appreciated.
I am new here so I don't know if this should go under 12 valve or 24 valve so I have posted both.
Old May 16, 2008 | 08:36 AM
Dshiftff's Avatar
you need a 98 12 valve wiring harness for it to talk with the newer style dashboard
Old May 16, 2008 | 08:51 AM
rich's Avatar
believe the 24v uses the crank and cam sensors to run the tach.i know thats how it was in the when we converted the 03
Old May 18, 2008 | 10:06 AM
Dshiftff....
I have spent alot on this conversion and have asked a half-a-million(or there abouts) concerning the 98 1/2 wiring harness and I have been told 'I don' t know if it will work". What makes you think that it will communicate with the '24' v computer? Just wanting to be totally sure before I buy a harness. Thanks, Scott.
Old May 18, 2008 | 10:08 AM
Rich,
Did you convert from a 24 valve to a 12 valve? If so, what did you do for the wiring harness?
Old May 22, 2008 | 02:41 PM
Dshiftff's Avatar
Originally Posted by DeerHunter812
Dshiftff....
Scott up at mass diesel did one with it and it worked great. I used the 01 harness and spliced in all my connectors, etc. A little more time consuming.
Old Jun 11, 2025 | 03:49 PM
Caleb Haines's Avatar
Hey I put a 12v into my 2001 3500 From a 24v does your tack work?
Old Jun 15, 2025 | 07:04 PM
Best way to do a 12v swap on a '98-'02 24V is using a complete 3 month '98.0 12V wiring harness.
Hard to find the right parts, but makes the installation go smoothly.
DeerHunter812
Mar 22, 2009 05:07 PM
DeerHunter812
Cummins Conversions
Aug 13, 2008 12:49 PM
tonyG
Jun 29, 2007 08:33 AM
mhuppertz
Mar 10, 2007 08:28 PM
dsljunkie
Jan 14, 2004 10:46 AM
