24 valve conversion to 12 valve
I Have A 1999 Dodge Ram 2500 Cummins Turbo 24 Valve 5 Speed 5.9L Truck That I Have Switched With A 1994 12valve Diesel Engine. I Need To Know Either Two Things. Does Anyone Know How To Hook Up The 1994 Wiring Harness(12 V) To The 1999 Ecm Unit? Will the PCM talk correctly to the BCM to get the tachometer to work?
Any help would be appreciated.
I am new here so I don't know whether to post this on the 12 valve forum or 24 valve.
you will need the pcm and all 1998 engine and trans harness, transmission and valve body should be the same, pcm on the new truck uses rpm and apps signals, the 12v uses cam and tp sensors as inputs. but i agree convert the 24v to a p-pump, i always wanted to do this. 1 more injection pump goes and 1 will!
The posts above seem to suggest that there is an option to convert a 24-valve to a 12-valve by switching to EITHER a p-pump OR by changing out the wiring harnesses+pcm. Wouldn't you have to change out all of it?
If I understand you correctly, you already have the 94 engine in place. In that case I would get a PCM and harness for a 98 12V, for an automatic if you have one, or a 5 spd if you have that and plug everything together and it should work. You may also need to get a 98 12V gauge cluster too, but I would try without it to start and if needed, get that part later.
You can get a plate made-up for the camshaft so you can use the existing tach pick-up sensor. Its relatively easy for stick truck, you just need the gearbox of a 12v, 12v camshaft (lift pump lube), 12v lift pump, fuel shut-off valve. You'll need a spacer for the air horn. Notch the head slightly for the pump. New injector lines for the new pump. Haisley builds a kit to do the swap. You could even get the throttle cable off the earlier truck. You might have to rig up a way for your cruise to work again. Later VP auto trucks need the APPS sensor for throttle position to shift correctly. I was just gonna build a spacer to lift enough to clear the P pump. Get the P pump brace off the 12v as well. I would run the 98 block, as there is a second drain for twins. Do a search on P pump conversion, there tons of info...
DeerHunter812
Apr 30, 2026 08:52 PM
dsljunkie
Jan 14, 2004 10:46 AM
