24 Valve To 12 Valve Conversion
Old May 15, 2008 | 08:55 AM
DeerHunter812's Avatar
I Have A 1999 Dodge Ram 2500 Cummins Turbo 24 Valve 5 Speed 5.9 Litre Truck That I Have Switched With A 1994 12valve Diesel Engine. I Need To Know Either Two Things. Does Anyone Know How To Hook Up The 1994 Wiring Harness(12 V) To The 1999 Ecm Unit?
If Not, Can I Buy A 1998.5 12 Valve Engine Wiring Harness So That The Computers Will Communicate Properly.
We Have No One Around Here That Knows Anything About Diesels. I Knew Enough To Get The Engines Changed But I Am Stumped On The Electrical. Also Do You Know Anyone Around Greensburg, Indiana That Might Be Close Enough To Help Out. Thanks!
Old May 15, 2008 | 09:31 AM
infidel's Avatar
12 valves don't have an ECM but they have a PCM.
The engine doesn't need the PCM to run but if you want gauges, wait to start grid heaters A/C and auto tranny shifting you'll need to pick up a '94 PCM and harness.
Old May 15, 2008 | 09:40 AM
The problem is will the PCM talk correctly to the BCM to get the tachometer to work.
Old May 15, 2008 | 11:29 AM
rich's Avatar
we couldnt get it to work on my 03 when we did it cause i believe the 24v and the 3rd gen motors take a reading off the cam sensor and the crank sensor
Old May 15, 2008 | 07:48 PM
What did you end up doing?
Old May 15, 2008 | 07:57 PM
OldDodgeOwner's Avatar
I don't know how it was done, but my friend has a 97 with a 24V swapped in and all the guages work fine on it, I don't see why it couldn't be done the other way around. Sorry I can't help ya though.
Old Aug 13, 2008 | 12:49 PM
Coagulation's Avatar
Muted User
I would just rip out that cluster and fab up a plate and mount some sweet aftermarket gauges to it.
DeerHunter812
Apr 30, 2026 08:52 PM
DeerHunter812
Mar 22, 2009 05:07 PM
tonyG
Jun 29, 2007 08:33 AM
mhuppertz
Mar 10, 2007 08:28 PM
dsljunkie
Jan 14, 2004 10:46 AM
