SLC Transmission
Anyone know a good Transmission shop in the SLC area?
moonlight diesel...:cool:
Adding more billet or did you have a problem with the Suncoast?
I know Gillett's Diesel uses Intermountain Transmission for their more serious tranny work. Like Mark said though, I would go with Terry up at Moonlight Diesel. |
Moonlight diesel
Where is Moonlight Diesel located
Originally Posted by BuildingBoost
(Post 1628194)
http://www.moonlightdiesel.com/contact_us.html Logan area..... |
Only Dealer
Is he the only "dealer" of the major brands? Are others closer to the SLC area?
well I like them cause they are a DTT builder..so thats why I would go with them.
what's wrong with your suncoast??? |
Eratic Shifting
It doesn't seem healthy. I has started to shift erratically between first and send and not seem to want to grab...under light throttle. I know this is something that is common, however it just started after 10K miles so I think something might be wrong. I want a good tyranny guy to look at it.
(Post 1628263)
any trans shop will tell you they can do this and that but moonlight builds true High HP trannys....but if you go to the local 5 star transmission or AAMCO you wont be happy..[nonono] just my .02 |
I went to J&g transmission to have mine built with all billet parts and heavy duty clutches etc. Anyone can build a high performance tranny. It just depends on what is put into one. They are in murray area and will give a 3 year warranty to boot. They have built trannys for sledpullers before also.
Originally Posted by 05 Thunder Beas
(Post 1628726)
Moonlight diesel ????? when was the last time one of there race trucks had over a hundred passes on one tranny and well Gillet or Guns & Roses is a whole other story. Maybe a Wide Open has an idea or hey even those one guys over at Industrial Injection might have one. But I also heard some guy at Best Buy is doin trannies on the side it will save you 500$[duhhh]
I don't know for sure if they do or not. It wouldn't surprise me. They are real good to work with.
