Which FASS to use?
Old Nov 17, 2007 | 09:43 AM
Derek Timm's Avatar
Which FASS to use?
Looking to add a FASS system to my 05. Only mods so far are a superchip programmer, MBRP, and airaid cold air. Would like to upgrade singl turbo and injectors in future. I am thinking fuel first and toys that can use it next.
Recomendations?
Thanks!
Derek <*)))><
Old Nov 17, 2007 | 10:07 AM
Derek Timm's Avatar
My it's quiet out there!
I know that it feels like I'm draining the fuel rail when I get on it fairly hard with the performance program right now and think it's both airatioin as well as total flow.
I know you guy's have "been ther done that"
THoughts?
Derek <*)))><
Old Nov 17, 2007 | 10:23 AM
BradyQB's Avatar
I started with 150gph/ switched to 200gph, plenty of fuel, pressure and definately fun. I started seeing the true potential of my Edge, and also injectors. Idled better, ran smoother and better milage during normal driving...
yfz450guy's Avatar
hpfp95 thats what i have and love it.
Old Nov 17, 2007 | 10:27 AM
BradyQB's Avatar
Fass150/200-1007 - more volume the better, with the mods you plan on doing you dont want to have to do it all over again!!!
Old Nov 17, 2007 | 10:33 AM
Derek Timm's Avatar
Thank for the replys.
Looks like I can most likely stay at the 95gph since I am only looking to get to about 450-500 HP.
Derek <*)))><
Old Nov 17, 2007 | 10:37 AM
Derek Timm's Avatar
Brady
I missed your post before my last reply. I am thinking fat shaft 66 and about 100hp injectors. Witht he programmer and these parts I don't think I'll be above 450hp. Did you drain the rail with the 150?
I agree I don't want to have to change out the fass if I don't have to.
Derek <*)))><
Old Nov 17, 2007 | 11:16 AM
BradyQB's Avatar
I actually had the phatshaft 66 before i swapped to the silver bullet, its a great turbo, if you have the extra $ i would go with a silver series, and the 90hp dragon flow injectors, and depending on the programmer i would guess you would be over or around 450 but i would def. suggest a hi HP clutch for your 6speed. The 200 seemed to be more responsive under load, towing and hi performance...The cost diff is only a few bucks so i figured what the hell!
Old Nov 17, 2007 | 11:18 AM
Jason A's Avatar
Any problems with the fuel pick up at lower tank levels as have been noted with the Glacier system?
Old Nov 17, 2007 | 11:26 AM
Derek Timm's Avatar
The clutch is definitly on the list with the FASS before any other mods. I have some slip if I get on it from low RPM's since the max torque is around 1800 rpms with the superchips.
CON/OFE and dump the dual mass flywheel.
Derek <*)))><
Old Nov 17, 2007 | 12:19 PM
BradyQB's Avatar
Havent noticed or heard of any problems with the fuel pick up at the lower tank...So far anyway!!!
Old Nov 17, 2007 | 03:11 PM
bluechrome's Avatar
A Fass 150/150 Will Keep Up With Dual Cp3's And 90hp Injectors No Prob.
Old Nov 17, 2007 | 05:25 PM
bwalker341's Avatar
wickeddiesels.com. Check out the eliminator fuel system. Mine is goin on next week (along with the Arson CP3 kit) and they are great people to deal with. I had FASS on my 98.5 and it worked ok...but it was loud.
Old Nov 17, 2007 | 06:16 PM
sliqwille04's Avatar
Have you thought about running an MP-8? It keeps my RP (i have it set on about 60%) right around 25000psi.
Bradleysram
19
May 12, 2009 08:36 AM
Spooler
Dec 27, 2007 11:19 PM
bocuso
27
Jan 18, 2007 12:54 PM
T398
Sep 18, 2006 03:00 PM
CASMOKIN
Nov 15, 2005 09:11 AM
