edge ez chip/programmer question
i got an edge ez: product name ezd1000c, for 03 early 04 with 305hp motor and i was lookin online for an instruction manual. i found one and it shows that it comes with an adjustable toggle for the 3 power stages. i do not have that adjustable toggle(got it from neighbor that bought his 03 and took it out, but he said there was no toggle)?? so how does a guy go about setting this chip without the toggle?
i do not plan on putting on my truck as i konw it will not work since i have a 2006
It is an older model, I have had one since 2004 and there is no switch, as said before you must remove the end cover and move jumpers to make changes. EZD1000C is the correct part number. If you have an 2006 as stated in your sig, this probably won't work for you, my box says 2003.
i had the same question with my 99 took off box and saw 3 sets of prongs one with blue plastic like connector do you just move that connector to the next set of prongs for next hp setting?
i just checked my edge ez and its the old one with the jumpers set on level 4 according to nascarjumper's diagram, but the one with the toggle only has 3 power levels is that correct?
gooseneck extender
I trying to decide between a B&W Texa4200 10"extender and the PopUp SB116 16" extender. Have a 32' wilson gooseneck and 1 ton short box. Anybody have any suggestions? How is the neck release lever for the popup?
Jason762
Dec 11, 2007 12:15 PM
WEATHERBY460
Jul 11, 2006 07:01 PM
imfletcher
15
May 12, 2006 08:31 AM
G-NOTE
13
Aug 16, 2005 02:03 PM
Big Smoky
Mar 15, 2005 06:15 PM
