edge ez chip/programmer question
i got an edge ez: product name ezd1000c, for 03 early 04 with 305hp motor and i was lookin online for an instruction manual. i found one and it shows that it comes with an adjustable toggle for the 3 power stages. i do not have that adjustable toggle(got it from neighbor that bought his 03 and took it out, but he said there was no toggle)?? so how does a guy go about setting this chip without the toggle?
i do not plan on putting on my truck as i konw it will not work since i have a 2006 |
Its probably the older style with jumpers inside the box. Unplug it and pop the cover off.
i have seen guys leave the toggle zipped tied under the hood before. so trace the wires first to make sure. then call edge.
It is an older model, I have had one since 2004 and there is no switch, as said before you must remove the end cover and move jumpers to make changes. EZD1000C is the correct part number. If you have an 2006 as stated in your sig, this probably won't work for you, my box says 2003.
i had the same question with my 99 took off box and saw 3 sets of prongs one with blue plastic like connector do you just move that connector to the next set of prongs for next hp setting?
1 Attachment(s)
I have a copy of the settings, lets see if I can post the scan copy.
i just checked my edge ez and its the old one with the jumpers set on level 4 according to nascarjumper's diagram, but the one with the toggle only has 3 power levels is that correct?
You are correct, only three settings on new.
ok i seen that and i was just wondering...so the new ones are rated for less horsepower on max setting
gooseneck extender
I trying to decide between a B&W Texa4200 10"extender and the PopUp SB116 16" extender. Have a 32' wilson gooseneck and 1 ton short box. Anybody have any suggestions? How is the neck release lever for the popup?
