need assistance to change serpentine belt
I got my new belt in hand and crawled around over and under the truck and am slightly confused. How does the belt go under the very bottom pulley (for lack of a better description) yet the electrical connection for the fan will not allow you to go around the fan? Is there a trick to this?
Pics and a detailed description would be awesome.
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
here is the procedure accordin to the book
CAUTION: When installing the accessory drive belt, the belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction.
Position drive belt over all pulleys except water pump pulley.
Attach a suitable tool to the accessory drive belt tensioner.
Rotate accessory drive belt tensioner clockwise. Place belt over water pump pulley. Let tensioner rotate back into place. Remove tool. Be sure belt is properly seated on all pulleys.
Doing this job on my 08 right now. Pulling the old belt was a bit of a pain. Pulled the air filter box out to get more room to work. Thanks for posting the diagram above. Going to help out a lot.
DodgeDiesel61
01-26-2019 07:45 PM
cincydiesel
24
09-09-2010 04:49 PM
klx650a2
09-30-2009 06:58 PM
xtoyz17
02-10-2009 07:46 PM
CTDowerTN
11-03-2007 11:09 AM
