change serpentine belt, but electric clutch wires in way?
Old Sep 30, 2009 | 01:00 PM
klx650a2's Avatar
I was looking at how hard it is to change the belt on this thing and it looks no too bad except for the electric clutch wires. I found where to disconnect them but where the cables run, seem be molded into a chunk of steel. Any tips on this?
Old Sep 30, 2009 | 05:46 PM
tnhtractors's Avatar
I changed mine on my 08 3500 and I didnt have to unplug any wires, most of the work was done under neath looking up, just used a ratchet to relieve the tension pully. Snaking it out wasnt so bad, but putting it back on was a pain, almost need another person to help with belt guidence
Old Sep 30, 2009 | 06:58 PM
Jfaulkner's Avatar
Muted User
Shouldn't have to unplug any wires. It isn't hard to change unless you have a fluid damper, then you have to remove the damper or almost completely remove the fan pulley bracket.
DodgeDiesel61
Jan 26, 2019 07:45 PM
klx650a2
Jun 28, 2014 04:09 PM
xtoyz17
Feb 10, 2009 07:46 PM
feveree40
Oct 3, 2007 03:59 PM
Commatoze
Oct 24, 2002 09:32 AM
