EB quits at 25MPH Any adjustment?
Old Aug 8, 2008 | 10:45 AM
coolbreeze's Avatar
I was on a really steep, curvy road. Some curves were best at 15, 20 MPH.
Grade is 26% (Ca 108). I didn't have any problems, but it would be nice if the EB didn't just quit at 25. Anyway to adjust it?
Old Aug 8, 2008 | 11:54 AM
Ctimrun's Avatar
Mine doesn't quit at 25 mph, at least not with tow/haul turned on. It pulls hard all the way down to a very low speed. I am not sure what speed it quits without tow/haul on, will have to try that out and see. Maybe there is something wrong with yours?
Old Aug 8, 2008 | 12:44 PM
megacabdad's Avatar
Mine stops at 20 MPH. I don't think mine is adjustable. Don't know if there is a difference between mine and yours. (Factory EB.)
Old Aug 8, 2008 | 12:46 PM
Dodgezilla's Avatar
Tow Haul and/or drop down to manual 5th or, better yet, 4th gear. In fourth it will almost bring you to a stop before it disengages....
Old Aug 8, 2008 | 02:52 PM
gsbrockman's Avatar
My observation has been that the brake disengages around 1100 rpm or so. I'm quite sure it's rpm based as opposed to mph based.
As Dodgezilla suggested, use tow/haul and max your upshifts to 4th or 5th gears.
Greg
Old Aug 8, 2008 | 03:29 PM
myfirsttruck's Avatar
It Engages/disengages with RPM - not speed. It operates if your RPM is above 1100 and then cuts out below the 1100
Old Aug 8, 2008 | 05:28 PM
coolbreeze's Avatar
I was down in 2nd, and the EB would just quit at about 25MPH. I'll get back up there and try it again coming down with tow haul, although the downshifts can be a little severe.
Thanks all for the replies.
Old Aug 8, 2008 | 08:10 PM
Dodgezilla's Avatar
What I have found lessens the harsh downshifting is to tap the brake right when I think it is about to downshift. I know the whole idea is to not use the brakes if you don't have to but doing this makes mine much less harsh. Tow/Haul makes a huge difference in how effective the EB works....
Old Aug 8, 2008 | 08:15 PM
MikeRP's Avatar
Coolbreeze:
The difference between tow/haul and normal mode is pretty dramatic on the downshifts. It is really agressive in tow haul and seems to work automatically all the way to a stop. Now without the tow haul........
When I'm empty, mine will work all the way down to a stop but I have to agressively downshift it manually. I haven't quite mastered it yet. However, my experience is that if you let it come down by itself on flat ground it cuts off at 15 - 20 mph. For some reason if the exit ramp is downhill the EB stays on a little longer. That seems weird right?
Old Aug 8, 2008 | 08:21 PM
RiddlerLS1's Avatar
The ecm seems to sense how quickly you are decelerating or how much you need for the EBrake to come into play. Downshifting manually i can get it to stay on sometimes in 2nd, but it seems like its only when i am needing it most, rapid decel. If im just kinda slowly coming to a stop then it seems to not come on at all in 2nd. Its really hard to put my finger on how to make it stay engaged in 2nd, but it seems like its only in a very hard emergency downshift or something to that affect.
Otherwise it shuts off automatically at 1100rpms and normally doesnt come on in 2nd gear at all. As a matter of fact, even in tow haul mode, my tranny wont automatically downshift into 2nd. It stops after 3rd
Old Aug 10, 2008 | 11:35 PM
espee's Avatar
Mine will very rarely come on in 2nd gear, and only when the shifter is in "D". Almost always drops out around 20-25mph whether tow haul, or manual downshifting. I read somewhere that when the torque converter unlocks, it's supposed to drop the ex-brake...
Old Aug 13, 2008 | 09:00 AM
coolbreeze's Avatar
On my truck, the EB will work down to 20MPH in T/H. The EB does work in second gear. RPM's don't seem to make any difference.
A little over 6,000 miles now. Really like the truck
1993D350
Mar 24, 2011 07:52 AM
p0wd3rp1l0t
Aug 9, 2010 07:08 PM
YFZ
Feb 23, 2007 10:05 PM
wadel1
Feb 19, 2007 05:19 PM
matt13moto
Jan 11, 2007 08:37 PM
