Front end shaking.. comes and goes.. 25mph to 40mph..
Old Mar 23, 2011 | 10:16 AM
1993D350's Avatar
I bought a 1993 D350 dually regular cab with a flat bed like a month ago.
Here is the problem I have...
The truck has a bad vibration/shake on the front, it does not happens all the time, but it is always between 25 and 40mph, when I turn the steering wheel to the right, it shakes a LOT, like if the front passenger tire is jumping of the ground... it shakes the whole truck, steering wheel...
Today when I was driving on the hwy, at 60/65mph, from time to time I could hear a vibration noise from the front,m but no actual vibration on the truck...
It doesn't matter if I'm in gear or neutral, so I don't think is anything with the transmission...
What it's strange, is that it comes and goes, like every 5 or 10 minutes... I think it happens more often when the truck is warm, but I'm not really sure about that.
What do you guys think it can be? Tie rod? Ball joint? U-joint?
Old Mar 23, 2011 | 11:07 AM
MoparMarv's Avatar
I know my truck had worn out king pins and at 35-40mph it would shake really bad. I would maybe check the wheel bearing torques and lug nuts. I had a wheel fall off and that did strange stuff before it happened.
Old Mar 23, 2011 | 11:10 AM
oilcan64's Avatar
based on you saying d250, this truck is 2wd so it cant be a u-joint up front. when you say in neutral, do you mean. in neutral while going down the road at that speed? if i had to guess maybe a bad wheel bearing? mine used to shake like crazy at 60 mph...outer right wheel bearing was the problem, when i took it out...well it wasn't pretty haha. someone else will chime in shortly with other probable causes....good luck with it!
Old Mar 23, 2011 | 11:25 AM
maybe368's Avatar
Try searching "death wobble". It seems to be relatively common...Mark
Old Mar 23, 2011 | 11:57 AM
ClassA4x4's Avatar
wheel bearings, tie rod ends, ball joints.
Old Mar 23, 2011 | 12:22 PM
torquefan's Avatar
Quite possible it's a bad tire. Try rotating the tires front to rear to see if it changes. Also, on first gen duallies the wheels must be centered with a couple of conical nuts before the wheel nuts are torqued down. Without centering the wheels, you will induce some vibrations.
Old Mar 23, 2011 | 12:39 PM
SmokemS's Avatar
y dont you first try the cheapest thing and rotate your back tires to the front...i had the same problem with mine i changed my tires and it was gone.....could be as simple as a broken belt in a tire
Old Mar 23, 2011 | 01:49 PM
foxtrot's Avatar
death wobble says "no matches found"
Old Mar 23, 2011 | 04:33 PM
1993D350's Avatar
What I noticed today is that it vibrates always from 25 to 40 (around), but some times it shakes (only if I turn the steering to the right a little, if it is straight or to the left, it is fine...)
Yes, that is what I meant... But a bad bearing would make some noise all the time?
I serched about that before, it is kind o similar to that, the only difference is that mine happens only if I turn the wheel to the right a little, if it is straight or to the left, it doesnt vibrat/shake...
I am going to take a look on that...
I think my front tires are a different size, have no idea why...
Old Mar 23, 2011 | 07:12 PM
1993D350's Avatar
I think I found the problem, upper balljoint.
Driver side:
Passenger side:
Old Mar 23, 2011 | 07:20 PM
torquefan's Avatar
Yep, the boot's open so there's a definite possibility that there's play there. Jack it up under the lower control arm, as far outboard as possible, the. Grasp the tire at the top and bottom and give it a shake.
Old Mar 24, 2011 | 07:52 AM
ClassA4x4's Avatar
check ALL ball joint and tie rod stem/studs and castle nuts for looseness - they can cause shaking too.
02ctd4now
Feb 25, 2017 07:35 AM
p0wd3rp1l0t
Aug 9, 2010 07:08 PM
hconstantino
May 3, 2010 12:15 PM
matt13moto
Jan 11, 2007 08:37 PM
JCHMOTOR
Nov 5, 2004 03:18 PM
