SOUTH BEND OFEK Installed
Old Jan 13, 2010 | 08:55 PM
LeaperV12's Avatar
Question SOUTH BEND OFEK Installed
Good day,
A little dilemma that has me more than paranoid
Just had a shop do the whole nine yards with a SB OFE and a SB flywheel, Fr & Rr seals on tranny, the brass syncro's have normal wear, nothing too bad.
Flushed all fluids with amsoil, even filled gearbox with just under 6.5 ltr of Amsoil Syncromesh 5W30
The clutch is holding stock power so far, pedal pressure feels stockish & engagement is almost stock too.
All is well except, there is a continuous chatter sorta sound at idle when the clutch is out. Soon as i depress the clutch, its gone. Is this normal ? No big deal though.
Heres the real problem: 4th, 5th and 6th gear, right after i am done shifting and start to accelerate, there is very strange chatter/shudder or should i call it a vibration like sound that comes from where the tranny is.
Actually, it sounds like some serious lugging just louder.
this noise peaks between 1300 - 1850 RPM and then around 2000-2100 RPM, noise is down and then not audible.
I have driven 650 kms (400 Miles) since the clutch was installed. Around 200Kms (125 Mi) of it was city, stop and go
My mechanic friend who does not have a large enough lift sent my vehicle to this transmission shop owned by 35yr experienced transmission veteran, also the mechanics friend and transmission contact
He installed it, test drove it and delivered it, i had a chat with him and was confirmed all was well.
They say i need to let it break in. Is this normal ?, should i continue to drive like my grandmother ?
I cant wait to turn my Smarty on
Honestly, very sorry for the long post but i waited a long time and tore my pocket book to bits to have all this done.
CANNOT AFFORD anything to do with the tranny any time soon
Thank you all very much
Old Jan 13, 2010 | 09:05 PM
NickBeek's Avatar
What you describe sounds like normal gear chatter to me. Can you take a video and post it?
Old Jan 13, 2010 | 10:10 PM
LeaperV12's Avatar
I am hoping it is Nick, I really am. I will try and record audio/video tomorrow, hopefully the mic picks up on the sound
thanks for the reply
keep it coming
Old Jan 13, 2010 | 10:35 PM
Wild04.5's Avatar
call Peter at SouthBend Clutch.. hes awesome to talk to and will work with you and through any problem you have.
good luck.
Old Jan 14, 2010 | 08:35 AM
Fisherguy's Avatar
My OFE wouldn't fully release when I first put it in, it's great now, just took a few miles to break it in.
I replaced my DM flywheel with a solid one, the gear noise took a little getting used to, the noise you're describing sounds normal to me but you never had a DM flywheel so I can't figure why you'd be getting more noise now..?
Old Jan 14, 2010 | 11:49 AM
D-Roc's Avatar
Just had the OFE installed in mine. It does it too...I think it's just the nature of the beast.
Old Jan 14, 2010 | 08:55 PM
LeaperV12's Avatar
Yes, thats why i little more puzzled as i always had a solid flywheel but if all is normal, the reason why i never heard this before could be because when i bought the truck, the clutch was on its last legs and the little bearing rattle when i turned the truck off was always present
but if it wasnt releasing:
Wouldnt the sound come thru all gears ? little grind while shifting ?
Old Jan 14, 2010 | 09:03 PM
LeaperV12's Avatar
Didn't know how to upload videos here so here goes youtube
1. http://www.youtube.com/watch?v=xVCYuMnyYAw pyro and boost arent hooked up yet
2. http://www.youtube.com/watch?v=RKNrF1wHLME
you will hear how when i ease of the pedal the noise dies
3. http://www.youtube.com/watch?v=2pxdxLngrz0
3rd video is the clutch in and out chatter at idle
the quality isnt all that great, thats all my phone could do
hope it helps or i will take the truck on a freeway and try again, feel free to comment.
thanks for all the replys, i feel better already.
Old Jan 14, 2010 | 09:06 PM
LeaperV12's Avatar
good luck.
Dont get me wrong, i am not doubting their product or i would have never bought it.
I am just hoping there is no problem and Peter will chime in soon . It's hard to find the time to drive to Edmonton on our famous death highway to get something fixed
Old Jan 14, 2010 | 09:25 PM
Fisherguy's Avatar
I knew mine wasn't releasing cuz it was hard to get into gear, could feel things spinning inside.
Call Peter, let us know what he says.
I couldn't hear any gear noise when you were driving, heard some at idle but didn't seam too bad, hard to tell though.
BTW, your exhaust sure sounds nice, what you running?
Old Jan 14, 2010 | 09:43 PM
LeaperV12's Avatar
Will call Peter tomorrow for sure.
Thanks
Stock stainless exhaust, its the intake thats doing the trick. Amsoil filter, 5 inch toilet flange, turbo silencer ring delete and deleted those plates inside the inlet tube.
Old Jan 14, 2010 | 10:07 PM
cLAYH's Avatar
The chatter in N is normal. I was warned about it before I bought mine.
Old Jan 15, 2010 | 03:16 PM
LeaperV12's Avatar
On the phone with Peter as i type: he completed my sentence even before i could explain. The noise is due to the disk design which is made as such so it's difficult to tear it apart
His suggestion: shift at higher rpm, transmission and truck will love it.
the chatter in N is normal. Both the noise and chatter will quieten down a little with time but by then i will have learned to ignore it.
So now its time to smoke some rice.
I have to add though: As others above said : Anytime you have a related issue, call Peter. Untill you call, It's hard to believe how someone can be so well versed, calm and explanatory that one phone call makes you feel at ease.
NOW THAT'S CUSTOMER SERVICE
Cheers South Bend
Old Jan 15, 2010 | 04:24 PM
PRO-NRA's Avatar
Peter and his brothers and all the employee at SB makes to notch product along with outstanding customer service. Peter is a wealth of knowledge and a pleasure to talk to. When my DMF finally dies a street SB DD will be installed.
6BTchev86
Jul 20, 2013 01:53 PM
dodgezilla04
Dec 4, 2006 12:25 PM
06dodgedrw
Nov 8, 2006 10:10 PM
bigman
Jul 22, 2006 11:45 PM
Muzzy
Apr 11, 2005 06:39 PM
