Just installed south bend clutch questions....
Got my southbend ofe clutch put in my rig. I have been taking it easy and trying to drive through the city to brake it in per southbend. My question is, it seems a little grabby when you take off just using the clutch with no right pedal. The first 10-15 miles it didnt do this, it felt like stock. Also at rpms less than 1000 i hear this gravely sound, it also does this when in reverse again with no right pedal. Are these symptoms normal? Will the grabbyness change as the miles climb? The truck only has about 250 miles since the clutch was installed. Thanks!!
Mine was pretty smooth from day 1, but I just came out of a grabby dual disc.
Now, after a few thousand miles, I would be hard pressed to tell it from a stock clutch. Perhaps only when backing, but it's still smooth.
bnold
07-11-2007 10:56 PM
bridleman
36
07-10-2007 01:51 AM
dodgezilla04
12-04-2006 12:25 PM
06dodgedrw
11-08-2006 10:10 PM
Muzzy
04-11-2005 06:39 PM
