Greasing front drive shaft
Old Dec 13, 2005 | 10:37 PM
MonroeDiesel's Avatar
Where is the eye hole for greasing the front driveshaft. Do i need an adapter for the grease gun?
Old Dec 13, 2005 | 11:03 PM
Dan MAYOH's Avatar
Angry
I have an 05 Quad Dually 4x4 6 spd and I don't have a grease point on my front driveshaft-total bummer. Guess that it will cost me $$$ later.
Old Dec 14, 2005 | 03:53 AM
PZM123's Avatar
Yes you need a needle fitting. Dan MAYOH look again real hard with a bright light. It took me 10 minuts to find mine the 2nd time I greased it. Sometimes they just hide!
Old Dec 14, 2005 | 06:24 AM
TAS05CTD610's Avatar
Front Zerk
Check my pictures, i have one where it's located. not the best picture but it'll help. Mine was painted over and had to scrap the paint off to even see the thing. You'll find it. When I do my u joints I'm going to use the Spicer triple seal no greasable. Greasable ones are a tad weaker than non greasable.
Old Dec 14, 2005 | 08:49 AM
robert chilton's Avatar
Your truck may not have a grease fitting. My 04.5 does not! I pulled the shaft out and disassembled the thing to grease the joints. It was a real PITA but definatly worth doing. The factory grease was broken down pretty good at 20K miles. The funny thing was the grease looked like a rainbow having atleast 5 different colors.
Old Dec 14, 2005 | 09:52 PM
We do have grease points. It was a topic in the new TDR mag that i dont get this was the reason for me posting it here, i thought someone must have the new mag
Old Dec 14, 2005 | 10:01 PM
If you have a grease fitting then you will need the needle adapter for your gun. I had to tear mine down to grease it. Trust me there was no fitting on mine. I spent plenty of time starring at a torn apart shaft double checking this. There is a weep hole in the center of the shaft but NO needle fittings.
Old Dec 15, 2005 | 08:59 AM
Steve034x4's Avatar
From: North of the Frost Line....near Priddis Alberta
I have an '05 as well...Get under the truck with a trouble light, driver side, and with the left fronr wheel raised so you can freely rotate it. On mine, there's a paint splotch on the u-joint (transmission side, above the skid plate) that when facing down, gives access to the grease point. Rotate the tire to turn the drive shaft. You do need a needle - don't put too much in there and blow the seal. I use a small one handed grease gun and 1-2 squirts every oil change at 5-6000 mi.
Old Dec 16, 2005 | 03:00 PM
Thank you!
Chuck Diesel
35
Oct 21, 2014 01:51 PM
wadesautoac
14
Jul 18, 2012 04:19 PM
applied_gravity
22
Jun 25, 2011 06:35 PM
cbrahs
May 18, 2007 11:20 PM
rjweiss
Mar 14, 2005 06:55 PM
