High Idle On Its Own On A 6 Spd
Old Dec 8, 2005 | 11:30 AM
StrokeThis2500's Avatar
Alrighty This Mornin It Was Cold Dow N Here In Texas So Before I Left For Work I Went And Started It Up It Ran Crappy For A Little Bit But I Went In The House And Then I Heard It Rev Up So I Went Back Outside Got In It And The Rpms Were At 1000 Is This Normal Or Whats Goin On
Old Dec 8, 2005 | 11:37 AM
SBishop's Avatar
It is normal. Info. is in your owner's manual.
Old Dec 8, 2005 | 11:38 AM
rammtuff's Avatar
The truck behavior is normal. Don't know about the cold weather (shiver)
Old Dec 8, 2005 | 11:40 AM
so its sapose to do that when its cold right
Old Dec 8, 2005 | 11:59 AM
Jeff K's Avatar
Yup, if it is below a certain temp your truck will idle up on its own to try to keep the engine warm.
Old Dec 8, 2005 | 01:11 PM
whitebuffalo's Avatar
mine did it for the first time this AM too. I had read about it on here. my truck didnt seem to mind the cold as much as i did.
Old Dec 8, 2005 | 03:08 PM
BlackSunShyne's Avatar
+1 on the high idle. Mine is six speed and does it on its own in the cold as well.
Old Dec 8, 2005 | 05:35 PM
Hounddog's Avatar
They ALL do since 03.Its the RAMP UP high idle through the cruise buttoms that need to be eaither programed or enabled depending on year model(04.5 up)auto's only until just recently.
Old Dec 8, 2005 | 09:09 PM
Festus's Avatar
"auto's only until just recently" - please explain. Are you saying that you can now set the idle with the cruise on the manuals now??
Old Dec 8, 2005 | 10:06 PM
smash metal's Avatar
My 04 does it. usually when the tempture is about 35 or lower
Old Dec 9, 2005 | 12:16 AM
Hounddog's Avatar
Have read where now a micro clutch switch and a probably TSB is going down the info hiway for the 6 speeds.The switch is available through Cummins now.A few have already had their 6 speeds enabled! But YES now the 6 speeds will be able to have the RAMP UP high idle.BUT not 03/04s(dang) Mopar part number 51754171aa or Cummin 4089851
Old Dec 9, 2005 | 07:50 AM
Nuttymopar's Avatar
I have a 05 auto. I do have the high idle enabled which I can use with the cruise control buttons. But also from factory that if it is below a certain temp outside, it will automatically ramp up to 1000 rpm. I have also noticed that even having the truck all warmed up and running fine. I am sitting waiting for the wife or whatever, tranny in Park, that after a few minutes, truck idles back up to 1000 rpm. So I'm not sure if it is because of the outside temp or if it is also tied in with the coolant temps also. As I have noticed that when sitting still (10 minutes or so) that my coolant temps start to go down (normal) and that is when I see the rpms go up to 1000.
Old Dec 9, 2005 | 08:16 AM
Hounddog's Avatar
Suppose too.Tied in to coolant temp.Its stop keep heat up to stop cyl.coaking.
Old Dec 9, 2005 | 10:30 AM
realsquash's Avatar
Not trying to pimp out the BullyDog stuff but I just looked at the latest updates for the Tripledog and it shows that it enables the high idle, and a whole bunch of new stuff for the 06 models...
https://www.bullydog.org/internet_upgrades/Readme.pdf
Still no CLDL for my 03 though
Andy
Old Dec 9, 2005 | 09:53 PM
StrokeThisCTD's Avatar
Andy
Correct. When i programmed my BD on my truck, it enabled the high idle Cruise control features.
