High Idle On Its Own On A 6 Spd
Old Dec 15, 2005 | 05:36 PM
JOHN LEWIS's Avatar
Does my 2006 6speed have the cruise control endabler buttons setup and how do you set it HELP
Old Dec 15, 2005 | 06:00 PM
Hounddog's Avatar
It probaby needs the NEW mirco switch kit(for clutch pedal) to enable it,or maybe not.Put park brake on,trans out of gear.Feet off brake etc.and turn cruise ON.If it comes ON then hit accel button and see.it might be addresed in the OWNERS manual.If IT dosen't work then it needs to be ENABLED with a DRB at the dealer.Then IT might need the micro switch for the clutch pedal.
Old Dec 16, 2005 | 01:53 PM
bigblock2stroke's Avatar
Yes, its a MOPAR option. It will need the micro switch and your dealer will have to enable it the same way as the automatic.
The 1000 ramp up is not just for warm up. Its also there for you guys that idle your trucks too long. We actually refer to it as the "extended idle" feature. It helps to keep your crankcase ventilation system clear.
Old Dec 16, 2005 | 02:39 PM
StrokeThis2500's Avatar
whats wrong with idling the truck to long does it hurt anytrhing
Old Dec 16, 2005 | 04:42 PM
Hounddog's Avatar
At LOW idle speed it does harm.To ALL diesels.They dobn't make enough HEAT at idle to throughly burn fuel.Rings stick,carbon buildup,cyliners being washed down with unburned fuel etc.diesels are designed to run at a continuious speed bbut under 1000 rpm is not it.Even in HOT weather its better to ramp them up to 1100 to 1500 rpm.Run for days at 1400/1500 rpm with no harm.The 89s had a hand throttle! Wish they ALL did.fire it up let run a few seconds and pop them to 1200 rpm or so.Aides in warmup also in friged temps.In COLD weather they'll idle forever at 750 rpm and NEVER open the thermostat.
DodgenIt
23
Dec 20, 2009 07:45 PM
pmtg
Sep 7, 2006 11:54 PM
raybob_99
Apr 4, 2006 04:31 PM
NCTURBOS
18
Oct 29, 2005 12:07 PM
