2002 6 spd flywheel on 2001 5 spd?
Old Sep 6, 2006 | 10:09 PM
pmtg's Avatar
im looking to upgrade to the 13" clutch and 1 3/8" input shaft...
i found a flywheel off a 2002 2500 6 speed (92000 miles) and wondering if it will bolt on my 2001 2500 5 speed equipped motor? i obviously know i need a 13" clutch with the larger input shaft as a result, but is there anything else that is needed for it to bolt on? is there a minimum thickness of the flywheel before it cant be used anymore? what questions do i need to ask the seller?
thanks for the help!
Old Sep 6, 2006 | 10:47 PM
GlennRMK's Avatar
Talk to Peter from South Bend clutch, he has new flywheels for the 13" conversion, with roller pilot bearings
That is what I have in my 6 speed
The only difference is the offset of the flyweel on the 6 speed
If you put a 6 speed flywheel in your 5 speed, you will need a spacer to move the starter and longer bolts.
I had to get shorter starter bolts when I put the 5 speed flywheel in mine.
Old Sep 7, 2006 | 04:55 PM
pmtg's Avatar
i'll speak to him concerning the conversion, i just have an opportunity to purchase this flywheel extremely cheap (way cheaper than what i'd pay for a new flywheel w/ the conversion).
the way i see it is: i purchase the flywheel, get it re-surfaced, then only need to supply the clutch and input shaft for it to be functional, and adjust the starter offset.
Glenn,
i guess im a little confused, why would you put the 5spd flywheel on your 6spd equipped truck?
Old Sep 7, 2006 | 11:54 PM
GlennRMK's Avatar
Because I wanted to put the clutch in myself and didn't have anyone that could turn it on the weekend(when I could do it). So, I had to have a new flywheel. I used the 5 speed flywheel from the 13" clutch conversion so I would have a new flywheel.
Jona Gold
29
Jan 19, 2025 06:36 PM
Dusty Ratcliff
Feb 13, 2006 04:15 PM
NCTURBOS
18
Oct 29, 2005 12:07 PM
