G56 Seepage
Old Sep 20, 2010 | 04:27 PM
Roperteacher's Avatar
G56 Seepage
My G56 is seeping out the top passenger side. Not enough to really worry about but gets a little grimy to the touch inbetween oil changes. Not near enough to drip. It USED to do it on the drivers side. That eventually went away. I had the clutch replaced about 4,000 miles ago and I had them ck it and they said it was DRY. No problems. Is there a vent that might be getting some seepage out the top???? Thanks!
Old Sep 20, 2010 | 05:48 PM
tryNto's Avatar
IIRC there have been posts about the boot on top of the shifter housing cracking and causing a seep...
Old Sep 20, 2010 | 06:24 PM
Danderson's Avatar
G-56 boot.
A member of one of these sites posted a much sturdier,cheaper replacement boot manufactured for the Moose brand ATV's. Part# M9206801. He stated it fits perfectly.
Old Sep 20, 2010 | 09:59 PM
Thanks. I'll keep an eye on it. When they dropped the trans they said everything was dry. Weird!
Old Sep 21, 2010 | 09:08 PM
gadget.35-06's Avatar
That boot is easily torn; Freedom out by you, Roper, tore mine and then wouldn't fess up to it when they replaced my clutch last year.
Old Sep 22, 2010 | 09:29 AM
Hey Gadget! Freedom is out of business. Russ, the head tech opened up his own shop just about a mile away called Maximum Diesels. They are the ones who put it in. I did have some seepage before it was replaced but now its different. Russ is a good guy and I have been talking to him about it.
Old Sep 23, 2010 | 12:03 PM
bcfreighttrain's Avatar
sounds like the boot definitely .. i have the same problem
Old Sep 23, 2010 | 11:19 PM
I know Dan was talkin' about moving to Warshington(yeah, I know, the Redneck spelling) as I was having the Southbend put in. Now it needs to be replaced again...it chattered soon after installation and has been noisy since day one.
Old Sep 23, 2010 | 11:47 PM
Hamilton713's Avatar
My bet is the boot. I just replaced mine.
Here is a link...
https://www.dieseltruckresource.com/...r-t178872.html
Old Sep 25, 2010 | 10:28 AM
mikelr's Avatar
The boots easy to tear during a clutch change...happened to mine. Only noticed the problem when I saw what you are seeing (wet trany case). The boot is silicone, I cleaned it with brake cleaner and patched the tear with red RTV, it has held fine for over a year now.
Roperteacher
Jan 26, 2010 10:56 AM
Common
Jul 12, 2006 09:31 PM
metuante
46
Jan 26, 2006 05:25 PM
Graphite600
Sep 10, 2005 03:11 PM
Ben
May 10, 2004 07:29 PM
