G56 Leaker
Old Nov 19, 2007 | 04:54 PM
NickBeek's Avatar
G56 Leaker
Guys, if you have G56 trans and are seeing a little leakage from it check this out. Mine started leaking right after the 3 /36 warranty was up. While getting some work done at the dealer the tech noticed the leak, and had the trans expert give a diagnosis. Since the leak was coming from the top of the trans he said it was the shift tower seal. I agreed and left it at that cause it wasn't leaking bad. I stopped by the parts department at my dealer and tried to find this seal and it doesn't exist so we figured it is just RTV sealed. Today I pulled the interior apart and found the problem, it is not the shift tower seal, it is the shifter boot. It is made from very thin rubber and it had a tear in it. I called for parts and found out this part is on national back order! Tried another dealer just to keep the first one honest and got the same info. Well red neck engineering will have to suffice, I got some balck RTV and "mended" the tear. I am waiting for it to cure while I write this. I have attached some pics of the culpret. Sorry about the crappy quality pics.
Old Nov 19, 2007 | 08:35 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
Mine has a larger boot that wraps partially up the stick under the leather boot. It acts more like a sound deadener as it wraps the lower part stick tightly. Is yours the same and just out of the picture? I haven't seen a leak yet. 47K now.
Chris
Old Nov 19, 2007 | 11:21 PM
NickBeek's Avatar
Yup, actually 2 more boots. The bigger rubber one and the faux leather interior trim piece. That little orange rubber one keeps the tranny all nice and sealed. It looks to me like it was torn during installation, because there is nothing near it that could tear it once assembled.
Old Nov 20, 2007 | 08:22 AM
ratlratl's Avatar
MMMmmmm.... Grits!!
Thanks, haven't pulled that one up yet. did you get any smell before you saw the leak?
Chris
Old Oct 2, 2008 | 09:43 PM
VFDFireman's Avatar
I just had the same thing happen to me. Only mine has two holes, one on each end of the stick. The photo below shows the one on the engine side of the stick. I'm surprised to find that this is the only thread on the subject on the whole WS. I too had to redneck engineer the thing until a replacement arrives.
This really ticks me off, only 60K on my truck.
Old Oct 2, 2008 | 10:36 PM
Sniper05's Avatar
That is probab;y whats wrong with mine i have seen some seapage hear latley and a rediculus smell of atf in the cab, gona pull all the gear around it and look tommorow, how hard is the stuff around the shifter to take off?
Old Oct 2, 2008 | 11:47 PM
chipmonk's Avatar
these all seem to be on '05-'06 trucks, the same years that there were problems with g56 leaks due to them being hauled around with forklifts while uncrated.
even if you're out of warranty, Dodge should take care of this on their dime.
Old Oct 3, 2008 | 12:56 AM
PRO-NRA's Avatar
Where was teh oil dripped at? I have a small wetness on the bellhousing but not enough to drip yet. I can't tell if its tranny fluid or engine oil.
Old Oct 3, 2008 | 09:43 AM
XLR8R's Avatar
I've seen those boots tear like that a few times now - usually just +4 aroma is all that escapes... I kinda like the smell (makes the day go by a little slower).
Old Oct 3, 2008 | 01:42 PM
mitternocht's Avatar
Mine did the same thing! At first I thought the case was leaking, but when I did my clutch I found the torn boot. My local "dealer"-ship wanted like $35 for the thing so I told ‘em to pound sand and I RTV’ed it. The thing is so thin that I figured I new one would just leak too. At least oil is getting to the top of the trans.
Old Oct 3, 2008 | 08:50 PM
NickBeek's Avatar
When this happened I had about 30K miles on the truck. The dealer replaced the seal under warranty and it has not leaked since. I now have 78K miles and rolling.
Old Oct 4, 2008 | 08:18 AM
levigarrett76's Avatar
i tore mine when i swapped clutches...i got it after a few weeks and put it on
Old Feb 28, 2009 | 12:53 PM
khsjeepr's Avatar
Well evidently I have entirely too much faith in my truck because I just finished installing a Southbend OFE clutch and IGNORED others' advice of telling me to have a replacement top shifter boot on hand. Anyways, just as everyone else, my top shifter boot is torn. I went ahead and put it all back together, but now I'm looking to find a replacement boot.
I called the dealer, and they said they don't stock that part. Does anybody have the part number for this seal or know of a place I can order one online?
Thanks in advance!
BTW: All the planets must have been in alignment because when we went to stab the tranny, we got it on the first try! It was an incredible moment! This was with transfer case attached too... Total install time - 6.5 hours. I'm now rocking a new Southbend OFE!
Old Feb 28, 2009 | 02:32 PM
Ace's Avatar
Ace
Translation: We don't like to help people that work on their own trucks.
Old Feb 28, 2009 | 03:59 PM
NickBeek's Avatar
No, none of them have them because they are always on back order.
