Fuel Rail Pressure
Old Aug 8, 2015 | 03:02 PM
TJAR66's Avatar
Fuel Rail Pressure
Hey all,
06 3500 135,000 miles all things are good, however I have been noticing my FRP running lower a than usual on my last run down the freeway. Filter is fairly new (change at same time as oil). I know I have been living on borrowed time for the pump so....What are the recommendations out there, FASS, Airdog, stock or..... Not too overboard with goodies now but who knows what the future holds. Lets hear recommendations
Old Aug 8, 2015 | 04:16 PM
hot_runner58's Avatar
I'm Air dog all the way. I have installed several and not had a problem. As well as my own with 55k on it. They did have problems years ago with a seal going bad, but have since corrected the problem. BUT, I know there are people on here that love FASS. Check out air dogs website, they have great info on there. pureflowairdog . just remember to get a pump big enough for your needs. I didn't expect to end up doing so many mods, and I am almost to the point of needing a bigger one.
Old Aug 8, 2015 | 05:29 PM
ftltmp's Avatar
I prefer the fass, I don't have any experience with the airdog but I would hope they work as advertised.
Old Aug 9, 2015 | 03:21 PM
TJAR66's Avatar
OK thats one vote for each lol. In my research I see the the there are issues with the pick up tubes? Some of this is old info are the issues fixed now>
Old Aug 9, 2015 | 09:51 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I used to sell AirDog products and quit because I could not in good conscience sell a product I knew was destined to fail prematurely
If you have any questions ask member Scotty how many pumps he has been through...they have replaced them under warranty but each time he is broke down, cant work his truck and has the cost or removal and replacement to deal with not to mention the aggravation......
Old Aug 12, 2015 | 04:56 PM
pdogg's Avatar
you guys realize you're talking about lift pumps? Fuel Rail Pressure, or FRP as is stated, is provided by an injection pump... two different animals on this truck..
Old Aug 13, 2015 | 03:16 AM
Steve-l's Avatar
For the OP, How do you know the rail pressure is low?
Old Aug 13, 2015 | 10:39 AM
TJAR66's Avatar
pdogg- Thanks for the info. I guess I need more education on my fuel system. I was thinking the new pump bypassed the IP.
Steve-l I monitor my FRP via an edge monitor. I have monitored that parameter since having the gauge. I noticed a lower than "normal" reading at idle and at freeway speeds.
Normal idle 7-8K current idle 6-7k freeway cruising Normal 17k+ current 15-16K.
My truck has been sitting alot lately but I did run a couple tanks through it last weekend, which is when I was noticing the difference. I am gonna put a fresh filter in and see what that does.
I know there is a wealth if information on the internet....but if anyone knows of a good reliable shop in or around Ventura County CA, that would be willing to share knowledge over a cocktail after hours let me know.
Old Aug 13, 2015 | 10:47 AM
pdogg's Avatar
for what it's worth, your Injection Pump is also known as a CP3..
Good Write up on the Bosch pump
Old Aug 14, 2015 | 12:39 AM
ftltmp's Avatar
FWIW, I have the cts2 and at idle it runs 6.8k and 16-18+ at highway speed
I have been told by edge that is where it should be, I think you are ok... just my
Old Aug 14, 2015 | 01:14 AM
Steve-l's Avatar
FRP gauges are nice to have, but feed pressure from the supply pump is more useful. You will note that fuel pressure will change with temperature and with seasonal fuel changes from the refineries, as does fuel consumption. There is less latent energy in winter fuel than summer, 10% variation is not unheard of.
Old Aug 15, 2015 | 10:16 PM
ironbrew's Avatar
Went through this with a markedly lower rail pressure. Leaky fuel tube to the injector.
5.9Excursion
Mar 13, 2008 10:56 AM
jgiachino
16
Jul 11, 2007 07:33 PM
subspd
Dec 24, 2006 02:01 PM
rjm022
Dec 14, 2006 05:20 AM
mtl0727
Nov 5, 2005 06:47 PM
