Does rail pressure drain to zero when truck is shut off? How about with a rail cap?
Old Mar 13, 2008 | 08:11 AM
5.9Excursion's Avatar
Is rail pressure suppose to drain to zero when the truck is shut off? How about with a rail cap?
Thanks
Old Mar 13, 2008 | 10:03 AM
jrussell's Avatar
It does drain to "0" with the stock configuration. Not sure with the rail cap, but I assume it would still drain down so you can open the system without killing yourself. AFAIK there's no real way to bleed the high pressure side of the system.
Old Mar 13, 2008 | 10:55 AM
no_6_oh_no's Avatar
Rail pressure will bleed off thru the rail return system when the truck is shut off. The rail cap is on the pressure relief valve and has no effect on the bleed off, only there to limit the max pressure.
Old Mar 13, 2008 | 10:56 AM
Thanks for the feedback, exactly what I was looking for.
dkimmel
Jan 3, 2011 10:54 PM
randyswelding
Feb 9, 2009 10:40 PM
VikingDiesel
17
Dec 30, 2006 09:19 AM
drew03
39
Nov 13, 2005 09:20 AM
darrenG
Jun 28, 2005 07:43 AM
