Is Driving 100% Tow-Haul a Problem?
Old Dec 25, 2010 | 11:46 AM
Al Ex's Avatar
I keep it in Two-Haul “all the time” because the shift points seem better suited to the truck the way I drive unloaded - don't tow anything…. Is there any problem with this? Will I cause any premature trans wear or breakdown?
I do run a Smarty JR @ 100% POD, but I drive very light footed and only use the power for passing acceleration when needed. I just don’t like the trans shift points in standard “drive” mode, never have. It seems like it holds shift points too long, especially going from 3rd to 4th (final shift @ 50 MPH). I’ve always driven it this way since new – now has 91K.
Old Dec 25, 2010 | 12:52 PM
bigwheels94's Avatar
I drive in T/H all the time, untill I cross the 60 mph mark. Then I'll let it shift into O/D for milage. Obviously this is depending on loads, & road conditions.
Old Dec 25, 2010 | 01:48 PM
Al Ex's Avatar
Tow-haul on the '06 allows OD in 4th, so you still get fuel savings benefits. But I seem to remember reading somewhere you won't get as good of MPG using TH. However, I've never noticed a difference myself... I always average about 20 MPG - slightly better in summer, less in winter.
Old Dec 25, 2010 | 02:02 PM
2007 5.9's Avatar
T/H everytime I put it in drive. Been doing it for 70k!!!
Old Dec 25, 2010 | 04:44 PM
Shorts's Avatar
I run in TH all the time. Hadn't had a problem.
Old Dec 25, 2010 | 05:14 PM
AkitaSumo's Avatar
God I hope not, been running it every day. First thing I always do before I take her out of park.
Old Dec 25, 2010 | 08:39 PM
Sevir's Avatar
i run it all the time under 60MPH, anything above that i click it off for mileage. it does improve mileage for around town driving.
Old Jan 4, 2011 | 11:23 AM
BPoulsen's Avatar
I always run in T/H - I lilke the shift points better. Been doing it for 60k with no problems.
Old Jan 4, 2011 | 11:41 AM
knc77's Avatar
T/H for 80,000 miles (provided I remember to turn it on when I start the truck ).
Mileage is an interesting comment. If I am correct, T/H (at least on my 05) simply adjusts the shift points and locks the TC sooner. I get OD and lockup at 45 mph rather than 50 mph with it off. I like the TC locked and would think not slipping the TC and wasting energy would be more efficient.
rjm022
Oct 14, 2010 05:08 PM
hotrod929
31
May 22, 2009 08:56 PM
rjm022
Jan 2, 2008 08:10 AM
rjm022
Dec 28, 2007 10:53 AM
