Code Question?
Old Jan 28, 2008 | 08:40 PM
mtblackdog's Avatar
Code Question?
Thanks for the help in advance. My engine light is on and my truck is throwing a P0336, wondering what is going on, it has been colder than a well diggers **** here, my truck is starting a lot harder in this years cold than last year, meaning same temps and alot harder start this year. Jamie
Old Jan 28, 2008 | 08:48 PM
ian515's Avatar
P0336
Crankshaft Position Sensor Signal
was it after an extended crank session? I recall seeing that one after cranking for a while, it went away after about 15 minutes of driving though.
Old Jan 28, 2008 | 08:51 PM
mtblackdog's Avatar
yep extended cranking period, but hasnt gone away yet?
Old Jan 28, 2008 | 08:59 PM
ian515's Avatar
hmmmm, have you started it a couple times since this first code popped up?
like I said, mine cleared after about 15 minutes and after shutting the truck off and on again once.
Old Jan 28, 2008 | 09:40 PM
mtblackdog's Avatar
Yep started it a couple of times. Still throwing the code.
Old Jan 28, 2008 | 09:43 PM
RamWheelsBy4's Avatar
It usually takes 4 start and run to full engine temp or close before the CEL/MIL will go out if the reason for initial code is no longer present. Just starting and turning off does not qualify as start and run to temp.
Old Jan 28, 2008 | 09:51 PM
ian515's Avatar
i guess mine was just luck, but it was up to full temp before I got back to the house and shut her down. about 5 minutes later I started it back up and the code was gone.
so yes, definately run it for a bit before shutting it down.
Old Jan 28, 2008 | 09:59 PM
BigTXDually's Avatar
If you continue to have this problem you might need to just go on and replace the crank sensor, I have people come into the dealership all the time with this problem and after I believe the cost is around $160-200 sensor the problem is gone. Unfortunately this seems to be somewhat of a common problem. Hope you can get it figured. Good luck
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
TEDHRS
Nov 9, 2002 12:35 AM
