Bought Texas Truck with no preheat
Old Aug 8, 2015 | 08:57 PM
Duck Soup's Avatar
Recently purchased an 06 "Lone Star" and don't see any provision for a block heater or preheat setup. In my area I have experienced -20 and am looking for advise as to whether or not the truck will start without a pre heat. I will add a pan heater anyway but often enough I won't be able to plug in. Any ideas would be appreciated.
Old Aug 8, 2015 | 09:08 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Buy the cord for the block heater it is installed in a freeze plug sort of behind the oil filter. They did not come with the cord but the heater is already there.
Old Aug 9, 2015 | 08:16 AM
madhat's Avatar
Administrator/Jarhead
It also has grid heaters that come on automatically, they are just below where the intake horn goes into the head.
Block heater:
https://www.dieseltruckresource.com/...nstall-223768/
Old Aug 9, 2015 | 12:06 PM
Duck Soup's Avatar
Thanks for the info. Will buy the plug. On my 01 I had a wait to start light. But this truck doesn't seem to have anything like that. Are you saying that it is automatic with no delay or wait to start light?
Old Aug 9, 2015 | 06:20 PM
gcssr's Avatar
The wait to start normally does not come on above 60, and in Texas their is no need usually for pre heat, much less wait to start, get in hit starter it fires right up. Up north is a different story, as stated get the cord installed and u have block heat;;;
Old Aug 9, 2015 | 08:36 PM
madhat's Avatar
The WTS light should come on as a bulb check when you turn the key on, then shut off after a second or so. This is a bulb check, not a preheat cycle. If it's not coming on at all, something else is going on.
The grid heaters won't come on over 55*.
Old Aug 9, 2015 | 09:26 PM
Duck Soup's Avatar
Yes, this is where I seem to have a problem. Bought the cord from Geno's, it's on the way. Grid heater is there and wired but light does not come on with bulb check. I realize the temp needs to be lower than 66 for heater to come on but still think the light (bulb check) only should show which it does not. Thanks again for your inputs.
Old Aug 10, 2015 | 07:56 AM
patdaly's Avatar
Could the bulb be burned out?
banks twinram
27
Oct 15, 2007 11:54 AM
ollie32
Sep 21, 2007 09:53 PM
mikal711
Aug 4, 2006 01:23 AM
DieselNut68
Oct 22, 2003 11:30 PM
Grant.G
Nov 11, 2002 03:57 PM
