Cummins Preheat Coil
Old Sep 11, 2007 | 06:23 PM
ollie32's Avatar
Been having a difficult time starting my truck in the mornings, cooling down up here. I have am pretty sure it is the preheat coil that isn't warming up enough. I have one on order
Just wondering if any of you have changed this piece, haven't even looked yet to see where it belongs? I am suspecting the the intake manifold someplace?
Any help would be great thanks
Greg
Old Sep 11, 2007 | 06:33 PM
soulezoo's Avatar
DTR 1st Sergeant
At the end of the intake horn next to the engine. It is a flat square thing that will have an electrical terminal and cable on it. It fits between the end of the intake horn and rests on top of the intake manifold.
Old Sep 11, 2007 | 08:34 PM
wreedCTD's Avatar
where are you located?
Old Sep 11, 2007 | 09:25 PM
InfernoB's Avatar
On my '07 5.9 the grid heaters are wired up. The solenoid cycles, etc. The only thing is the heater will not turn on since the factory did not run the ground wire from the grid heater to the manifold. Check yours.
Mines a CA truck, so really don't need it either.
Old Sep 11, 2007 | 09:40 PM
PourinDiesel's Avatar
Greg
Make sure to order a couple intake gaskets because they will not be re-usable.
Old Sep 21, 2007 | 07:21 PM
InfernoB's Avatar
I've found out that my heater does work. The system grounds through the housing of the grid heater. Today it was cool enough to retest operation.
Thanks.
Old Sep 21, 2007 | 09:53 PM
CG98x's Avatar
They changed the gasket design so the ground wire is not necessary.
Duck Soup
Aug 10, 2015 07:56 AM
banks twinram
27
Oct 15, 2007 11:54 AM
mikal711
Aug 4, 2006 01:23 AM
jt
Mar 20, 2003 08:54 PM
Grant.G
Nov 11, 2002 03:57 PM
