Anyone know what fuse this is?
Old Aug 13, 2019 | 06:53 PM
Spencer1096's Avatar
Bought a 1995 12 valve Cummins not too long ago just as a project truck. There was a big fuse wrapped in electrical tape zip tied to other wiring. If anyone could tell me what it is and possibly where it goes I would appreciate it.
Old Aug 14, 2019 | 12:13 AM
AlpineRAM's Avatar
To me this looks like the alternator wiring loom. Small spade looking thingies go to the brushes, bigger thing on the same hard plastic is alternator output and the free fat end goes to ground if I recall this correctly.
Old Aug 14, 2019 | 07:08 AM
Fordzilla's Avatar
Are any of the exposed terminals either powered or grounded?...Could be an important clue......Ben
Old Aug 14, 2019 | 10:20 AM
As mentioned that bolts to the back of the alternator.
On a side note air filters bolted directly to the turbo, that suck in the hot air right off the exhaust manifold are a terrible "mod" in my eyes. The factory air box is much better for your truck, with lower temp. air that is filtered better.
Old Aug 14, 2019 | 10:36 AM
texasprd's Avatar
Agree with AlpineRam that it is that the alternator loom - however, I have an illustration showing that the free end is alternator output (B+) and the larger terminal on the plastic piece is ground (larger illustration is from FSM/AllData - same terminals, just upside down from each other). If you have a factory alternator, you could (carefully!) mock it up against the back of the alternator to see which reaches the alternator's B+ terminal and which connects to ground terminal. The small spade-like terminals go to field-control terminals and are usually held on with nuts.
Does the truck currently have an alternator - if so, what kind and what's in place for charging control?
Old Aug 14, 2019 | 04:53 PM
AlpineRAM's Avatar
Ooopsie- may have swapped alt output with ground... sorry for that.. please video result..might offset damage from my mistake..
Recommendation- get factory service manual for your year of truck- extremely well spent $.
My mistake for your year of truck would have bought you 10 to 20 manuals..
Old Aug 15, 2019 | 03:03 PM
texasprd's Avatar
GenosGarage has the FSMs on paper - buy once, cry once unless you tear a page or spill something on it... Some people say the paper copy is best for following wiring diagrams.
AllDataDIY has most/all of the FSM info in electronic format - it's a per-year/per-vehicle subscription. First vehicle each year is the most expensive - additional vehicles are cheaper. Its the FSM data and diagrams (printable), broken out and searchable. I have on occasion seen some inaccuracies - something that applied to the gas engines, or an incorrect transmission plug (maybe for the 47RH, where mine is 47RE), but over all its pretty good.
PM'ed you with a link to a source for free, downloadable FSM...
The FSM info is just as important of a tool as a ratchet or multimeter - worth the $, as AlpineRams said.
Old Aug 15, 2019 | 03:53 PM
AlpineRAM's Avatar
Well, being in Austria, one ocean away from any chance of a shop that is used to fix these trucks the factory service manual was worth about it's weight in gold. (for the print version)
All the nice hints you get from the internet may not pertain to your year of the truck... but they might just have swapped plus to ground at this model change.
So buy the bugger for some $ (less than a box full of fuses) and do it right for your vehicle.
Old Aug 16, 2019 | 07:30 PM
It was in fact wiring for the alternator. Thanks everyone
fatt
Feb 12, 2014 10:23 PM
Brian.B
Jan 31, 2012 07:21 AM
normht
Jul 29, 2007 03:39 PM
GSP
Jun 29, 2007 12:06 AM
quantrill88
Dec 17, 2003 07:01 AM
