voltmeter at 8
Old Jul 29, 2007 | 10:45 AM
normht's Avatar
voltmeter at 8
The other day as i was changing the oil filter i shorted between the alternator and the block and got a small arc.Now i noticed the volt meter at about 8 volts.I removed the alternator and had it checked and it checked good.I noticed at the end of the wiring harness where it connects to the 2 small screws on the alternator there is a small rectangular plastic box.Its sealed and you cannot get it apart but i suspect my problems in there. Any idea's?
Old Jul 29, 2007 | 10:55 AM
Fueling around's Avatar
Look for a blown fuse in the PDC. It is a 120 amp cartridge and about $7
Old Jul 29, 2007 | 11:06 AM
normht's Avatar
Thanks for the fast response.Just what is a PDC and where is it?
Old Jul 29, 2007 | 11:19 AM
Power Distribution Center.
Black box under the hood near driver side battery.
Old Jul 29, 2007 | 11:42 AM
normht's Avatar
thanks I'll check it out
Old Jul 29, 2007 | 03:39 PM
normht's Avatar
Thanks Fueling around,you were right on the mark.The fuse was blown.I replaced it and now I'm good to go.Thanks again.
Vaughn MacKenzie
32
Nov 15, 2007 04:41 PM
RVT223
May 25, 2006 12:27 PM
RODGERDODGER01
May 22, 2006 09:42 AM
TexasHardcore
Jul 27, 2004 11:23 PM
quantrill88
Dec 14, 2003 06:41 PM
