check gauges light on........voltmeter reading zero
Old Dec 13, 2003 | 03:43 PM
quantrill88's Avatar
well u know its not a good day when u have to post in the "HELP" forum twice :.
anyhow, today i changed the oil and fuel filter, everything seemed to be running fine for the first 5 minutes. then the check gauges light came on and the voltmeter read zero. i turned around and went home, check the battery terminals just in case and fired it back up..........5 mins later, same thing. tried it one more time and it seemed to be ok but the voltmeter seemed a bit low at 10 or 11.
could this be from all the times i bumped the starter to run the lift pump to prime the system? i dont see how this would make any difference but i did have to crack an injector line to get it to prime.
any help would really be appreciated cuz i dont wanna drive anywhere if its goin to hurt it but otherwise im kinda stranded
thanks
jeff
Old Dec 13, 2003 | 03:59 PM
AlpineRAM's Avatar
Re:check gauges light on........voltmeter reading zero
I'd look at the connectors and cables at the back of the alternator. Maybe you have disturbed one of them when changing the oil filter.
AlpineRAM
Old Dec 13, 2003 | 04:05 PM
J BODY's Avatar
Any chance you "sparked" when changing the oil? I have seen and experienced contacting the back of the alt with an oil filter wrench when changing oil and popping the maxi fuse in the pdc. Something to look at anyways.
Old Dec 13, 2003 | 05:28 PM
er ummm, yep, that is what i did : >. had a bit more trouble getting the oil filter off than usual and i guess got a little carried away with the wrench. sparked against the alternator and i think luckily only took out the fuse.
however, i seem to be having a problem find a 140 amp fuse anywhere. ive tried NAPA, autozone, advance auto, pepboys, etc. with no luck
does anyone else have any ideas on where to get one? (other than the dealer, they arent open on sunday >)
thanks u guys for all your help
jeff
Old Dec 13, 2003 | 05:55 PM
J BODY's Avatar
Still dealer only as far as I know. Kind of spendy too if I recall.
Old Dec 13, 2003 | 06:08 PM
yea, seems like everything the dealer sells is way too expensive.....
Old Dec 13, 2003 | 07:42 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I think the dealer is the only place that carries that fuse. :-
Old Dec 13, 2003 | 07:49 PM
> crap.......
i was afraid of that....i called all over the place and the highest i could find was 120. to bad tomorrow is sunday.
driving a 4 banger jeep with 33's and a locker down 95 aint goin to be to fun....
if anyone knows anywhere i can get one of these please let me know
thanks
jeff
Old Dec 13, 2003 | 08:37 PM
Shovelhead's Avatar
Just for giggles, ya might try a junkyard.
I think there's a couple down near you.
Old Dec 13, 2003 | 11:36 PM
kandgo's Avatar
I found mine at autozone,had to ask as they were not out on the floor,I am in Oklahoma ,so do not know if every autozone carries them,I also was able to pick up a couple of spares for all the other size fuses under the hood. Might try them once more,Goodluck Rick
Old Dec 14, 2003 | 05:37 AM
pappyman's Avatar
I popped that fuse too got one from Pep Boys Auto Parts
Old Dec 14, 2003 | 10:05 AM
well i opened up the phonebook and started calling around, no one seems to have one that size. (oddly pepboys did have a 175 amp).
the big rig places are mainly closed. looks like ill be waiting till i can get one from a dealer :-
thanks guys for all the help
jeff
Old Dec 14, 2003 | 12:36 PM
Dave1997's Avatar
If the 120 fits and isn't too expensive I would go with that until I would get a replacement 140.. I tend to think the 120 would carry the load most of the time .. I don't know how often the system runs at maximum 140 amps... just a thought
Old Dec 14, 2003 | 06:30 PM
torquefan's Avatar
The 120A may not last too long, especially in a cold climate. The preheaters can draw 120A each after the engine starts.
Wouldn't last a day up here in the north. ;D
Old Dec 14, 2003 | 06:41 PM
well as it turned out, the 120 amp wouldnt have fit in the fuse box anyways (too wide). ill just have to wait till i get home on tues and get one from the dealer.
once again, i appreciate all the help
jeff
zethtays
Jan 22, 2012 10:35 AM
mopar-or-no-car
Jan 22, 2010 11:52 AM
82NDSNPR
Jul 25, 2008 03:26 PM
cluckmaster
13
Jan 23, 2007 12:43 PM
Fisherguy
Jan 22, 2007 09:18 PM
