alternator/charging issues
Old Jul 11, 2013 | 11:56 PM
fatt's Avatar
When I replaced all my fusible links with fuses, I also put an 80 amp fuse on the thick wire that comes from the alternator to the battery. This worked fine for about a year and a half but a few days ago the fuse died. I put a new one in and within a mile of driving the fuse and holder were a smoking pile of melted plastic. I just replaced the voltage regulator today and after about a minute the wire was getting hot so I pulled the fuse and drove home. What could be making that wire get so hot?
Old Jul 12, 2013 | 12:01 AM
JimmieD's Avatar
Well it sounds like your fuse is too high amperage rating. Instead of blowing from over-amperage it's cooking the wiring.
I'd take a close look at all the grounds, including voltage regulator grounding.
Old Jul 12, 2013 | 06:36 AM
Jim Lane's Avatar
Your Nippon-Denso alternator is rated at 120-amps, if you use an 80-amp fuse on the charge wire it will eventually fail from overload, after starting your engine the alternator is going to try and produce maximum current for a short time to recharge the battery especially in the winter when your grid heaters are activated, they are rated at 200-amps each.
Use at least a 120-amp maxi-fuse and upgrade both the alternator to battery wire and the case ground to battery wire using #2-gauge welding cable.
The wire could be getting hot and melting because of a loose connection at the burned wire, when a fuse holder overheats, the spring clip looses tension now creating loose connection on the new fuse.
Also check your battery voltage, you could have 1 shorted cell creating a 10-volt battery and your alternator will try to push 120-amps @13.8 volts into it and since the fuse is the weakest link it will melt.
I have a 200-amp "T" fuse on my alternator, it is only for a catastrophic failure of the wiring or the diodes on my 160-amp alternator.
Can you connect a DVM and tell us what the battery voltage is (engine off) and the charging voltage is at a fast idle?
Jim
Old Jul 12, 2013 | 07:50 AM
JimmieD's Avatar
My info regarding fuse amperage rating was incorrect, thanks Jim Lane!
Old Jul 12, 2013 | 08:48 AM
fatt's Avatar
I should mention that I had to get a new fuse holder since the old one melted so bad. I watched the volt meter on the dash when I ran it yesterday and it only got up to about the first mark. I will check the battery voltage today after work.
Old Feb 12, 2014 | 10:23 PM
fatt's Avatar
Ok update on this: I have now replaced the battery, alternator, and voltage regulator. I put a 175 amp fuse inline and it popped that as soon as I got on the road (RPMS going up) from the parking lot where I put it in.
Just now I replaced the wire from alt to battery and the green one from the alternator to the voltage regulator. Now when I started it(had to jump it) it doesn't charge at all, where before it would charge at idle but once I get off my driveway onto the road (again, getting RPMS up) the fuse would blow almost immediately.
5.9Excursion
Mar 13, 2008 07:08 AM
mwolfe
Jul 28, 2006 10:24 AM
Munchies
May 27, 2006 10:30 PM
MSM
Mar 12, 2006 12:46 PM
miningman
Nov 2, 2005 07:34 PM
