fuel filter drain leak
Old Mar 16, 2009 | 02:01 PM
klx650a2's Avatar
Well, since I replaced my last fuel filter I've had a slow drip from the drain on my fuel filter. Does anyone have any ideas how to fix it or can it be replaced? It looks like there are just 2 screws holding it to the fuel filter.
Old Mar 16, 2009 | 04:26 PM
TexMexCowboy's Avatar
I have had the same problem.
Old Mar 16, 2009 | 05:58 PM
Fishin2Deep4U's Avatar
Lot's of these leaking since the change to ULSD.
It can be replaced.
Dave
wantedwolf's Avatar
I think this happened to me too and at the worst time I might add.
i found a small ?sand? partical that must have pluged the drain valve open.
getting it clean was the hard part but keeping it clean what I did was:
I suspected it came up from the tubing as it looked to dirty so I drilled air holes in a sealed plastic bottle and taped the tube inside.
no problems since i did that 14000km ago
Old Mar 16, 2009 | 06:36 PM
Wild4kst8's Avatar
i thought i had a similar problem... pushed down on the "plunger" that the lever pushes up, and problem solved... just something to check
Old Mar 16, 2009 | 06:40 PM
littlebuddie's Avatar
I think this is the fuel drain valve for the 2000. Mine is different on my 1999. Might the o-rings be fatigued? Looks like they're easy enough to replace. Use BUNA o-rings, more expensive but they won't succumb to fuel damage like the standard hardware store cheaper version will.
Old Mar 16, 2009 | 11:14 PM
PChouinard's Avatar
Be sure to lube the entire o-ring with fuel, oil, or petroleum jelly (pet) prior to install. When the o-ring is sealing properly, only a small portion is exposed to the fluid and the rest is prone to heat and dryness. Installing it with some pet will extend it's life.
Old Mar 17, 2009 | 02:08 AM
Ed ke6bnl's Avatar
my boys leaked 2000 dodge, dodge wanted $75 got the whole part and new o ring from cummins $17+ shipping piece of cake to change out. Ed
Old Mar 17, 2009 | 09:37 AM
klx650a2's Avatar
I have fiddled, fondled, caressed, swore, tightened, pushed, pulled, loosened, jiggled and cannot get the "thing" to quit leaking. I phoned dodge and they want $42.00 for a new one and it will be here this afternoon.
Good thing I just put heat in the garage as its -22 here this morning...
This truck is starting to nickle and dime me to death...
Old Mar 19, 2009 | 11:00 AM
klx650a2's Avatar
Well, new one is on, only took 4.5 hours. Stripped out the threads on the engine side. Boy that aluminum is soft. 2 fingers on a 1/4 inch ratchet and "click". Could not get a tap in there, just got a slightly bigger screw with a nut for a spacer and now no more leaks (till the next one). Washed everything off and all is well on the Cummins...
Old Mar 20, 2009 | 10:27 PM
Kennys's Avatar
Bought several of the kits to repair this from Cummins for under $10 each.
RDMueller
Jan 25, 2011 07:14 PM
ZPOD
18
Sep 23, 2010 10:37 AM
klx650a2
Jan 10, 2008 12:08 AM
NoSparkplugs
Nov 9, 2006 07:48 AM
wooff
May 1, 2003 11:22 AM
