Radiator drain valve won't drain
Old Jan 9, 2008 | 09:01 AM
klx650a2's Avatar
I am moving the puke bottle and removing the rad to pressure wash it and turned the drain valve to drain it and nothing happened. Some dirt fell out when I moved the plastic valve but no fluid, ended up siphoning the antifreeze out. Question is which position SHOULD the drain valve be in to seal??? Vertical or horizontal??? It was vertical to start with, but logic tells me it should be horizontal...
Help?
Old Jan 9, 2008 | 09:56 AM
jj3500's Avatar
hmm? I did mine over a year ago. Can't remember. I did find specific info. when I did a search though.
Old Jan 9, 2008 | 11:15 AM
Shovelhead's Avatar
Administrator / Scooter Bum
The petcock is a twist and pull valve.
Old Jan 9, 2008 | 12:14 PM
klx650a2's Avatar
NOW you tell me... oh well, the antifreeze is tasty...
Old Jan 9, 2008 | 04:22 PM
supr's Avatar
Unhappy
Be VERY careful with the radiator. It does not take much to put a hole in it.
Do not ask how I know.
Old Jan 10, 2008 | 12:08 AM
SIXSLUG's Avatar
Push it in and turn it clockwise like most other on/off valves. It will seat all the way to the left. Don't over tighten this plastic wonder as it can get brittle over time! Kurt
Dieselnick
15
Aug 13, 2011 04:36 PM
sgc
Oct 31, 2008 07:55 AM
RHC
Oct 26, 2007 06:22 PM
6cylinders
Mar 6, 2004 03:57 PM
015speed
Jun 16, 2003 04:58 PM
