radiator drain valve clogged
Old Oct 28, 2008 | 02:36 PM
sgc's Avatar
sgc
Unhappy radiator drain valve clogged
i just tried to change my coolant and found that the drain is clogged. Can anybody help?
Old Oct 28, 2008 | 02:44 PM
Dartmouth 12V's Avatar
Is it truly clogged or did you not actually open the drain? When you turn the plug, you need to pull it out as well. If it just turns, then it won't drain. It will come back a noticeable amount when you turn it.
If it truly is clogged, try sticking a zip tie up there and seeing if you can free it up.
Old Oct 28, 2008 | 10:52 PM
wcbcruzer's Avatar
I'd be careful with the plug, especially if it's seized on like that. I'd be scared that it'll leak, or worse, break off. Another way, that's quicker as well, is to pull the lower radiator hose off. That's not real easy either but at least you can pick.
Old Oct 29, 2008 | 11:15 AM
Baja's Avatar
I would pull the hose. I have had nothing but trouble with the plug, it is a really bad design. It strips easily unless you are very careful. If you have already pulled it, get a new O ring for it and use grease or anti-seize compound when you put it back in. Dartmouth12v is right, you have to pull it out about 1/2" as you turn it. You also have to do the right amount of pull as you twist, or, again, you strip it. If you have it out, try compressed air to blow out whatever is in the way.
Old Oct 30, 2008 | 01:04 PM
Lil Dog's Avatar
And wear goggles when you pull on it.. Mine stripped out and came completely out. I got a nice hot glycol shower and flooded my garage. That plug is not a very good design at all!!
Old Oct 30, 2008 | 08:38 PM
sgc's Avatar
sgc
thaks for the tips
i will try to get the plug to come out some, mine just turned 90% kinda like a ball valve. only it started *l* and turned counterclockwise to *-* which is backwords compared to any valve i've used. maybe it was already open?
Old Oct 31, 2008 | 07:55 AM
SoTexRattler's Avatar
Same problem here... I opened the port and not a drop came out.. Piece of JUNK! I briefly considered pulling the plug out and trying to rod the pluggage out, but realized if I screwed-up the plastic sealing surfaces, I'd be out a radiator! I tightened it back up and left it alone... Best to pick your own battles...
Just go get a roll of vinyl tubing from Home Despot and insert it down the radiator cap port as far as you can and siphon the majority of the coolant into a 5gal bucket.. After the siphon breaks and no more can be drained via the tubing, NOW drop that bottom rad hose.. A much smaller hot green shower will result.
sherod
Aug 31, 2013 09:49 AM
Dieselnick
15
Aug 13, 2011 04:36 PM
klx650a2
Jan 10, 2008 12:08 AM
RHC
Oct 26, 2007 06:22 PM
6cylinders
Mar 6, 2004 03:57 PM
