4wd light
Old Mar 18, 2009 | 10:45 PM
Nick02Ram's Avatar
4wd light
When I kick it into 4x4, the light won't come on. Is that the sensor on top of the transfer case, and if so, are those known for going bad or anything? I tried tracing wires back, but they seem fine. First I noticed it was a while back when my buddy talked me into jumping a snow pile in a parking lot... Not sure if that had anything to do with it or not
Old Mar 19, 2009 | 01:42 PM
Busboy's Avatar
Check the axle disconnect. There should be two vacuum lines running to it, chances are you knocked them off in the snow.
Old Mar 19, 2009 | 04:07 PM
Dinner's Avatar
Check the vacuum lines, electrical wires and the CAD unit itself (down on the passenger side of the front axle). There will be a black and red vacuum line leading into the CAD. If your wiring and vacuum lines check out good, then it is probably the CAD unit itself. If the plunger inside does not move all the way to the left when put into 4wd, the light will not illuminate.
Old Mar 19, 2009 | 11:58 PM
Nick02Ram's Avatar
Thanks for the advice guys, havent got a chance to really check it out yet. I remember reading something about vac tubes before...but I don't remember seeing any under there last time I was lookin at it. Are all these trucks vacuum disconnected? I outta look before I post, but no sense in searchin for something that ain't there.
Old Mar 20, 2009 | 12:04 AM
huntman509's Avatar
the 2002's dont have a disconnect axle in them, should be a 2 wire switch on the t case jump across it and see if the light comes on, if so relpace the switch
Old Mar 20, 2009 | 02:13 PM
Busboy's Avatar
I thought it was 2003 they dropped it? I'm probably wrong though.
Old Mar 20, 2009 | 05:51 PM
nitrousn's Avatar
Yes they do. Mine does.
Old Mar 21, 2009 | 12:20 AM
Nick02Ram's Avatar
That did it, stuck a paper clip in the plug and my light came on, so i'll get a sensor tommorow, thanks a bunch. Glad I climbed under there, figured I may as well tighten my oil pan bolts, check the universals and my tranny fluid. Always workin on everyone elses vehicles, never get time to mess with my own.
p0wd3rp1l0t
Jun 27, 2012 10:29 PM
wrangler04
Jul 17, 2007 11:00 PM
VikingDiesel
Competition / Pulls / OffRoad
Dec 29, 2006 07:17 PM
95black2615
Dec 20, 2006 06:37 PM
1320
May 6, 2003 06:30 PM
