White/Blue smoke need help please.
Old Oct 10, 2014 | 07:08 PM
Mopar_Aaron's Avatar
My 92 d250 has been smoking white/blue, and exhaust starts popping once you start to get on it. Its a stock truck, Has 232,761 miles. Did a recent oil, and fuel filter change. What things should I be checking? I'm thinking that it could be a fuel sending issue, but I did recently find out that the previous owner did not use the truck as frequently as he had said. The truck had sat for awhile without being driven. Was hoping it was just bad old fuel, instead of an injector or piston ring issue. Need some help any advice would be great.
Old Oct 10, 2014 | 07:15 PM
Could be a bad injector(s)? But blue/white is usually air getting into the system.
Old Oct 10, 2014 | 07:18 PM
right thats what I was thinking but was wondering if the lift pump or injection pump could be an issue.
Old Oct 10, 2014 | 09:09 PM
Popping and smoking white when "getting on it" is a sign of starving for fuel.
I would think fuel/air leak in the lines/connections, or a bad lift pump.
Old Oct 10, 2014 | 11:14 PM
Justwannabeme's Avatar
DTR Mom
yuup, sticky lift pump when it performs (bucks) with the more demand for fuel. first thing I would do it hit it with the chemical cleaner at idle, play first range well. if no change, got to start the pressure testing then....then take money off the tree.....hoo boy.
diesel basics: white (air problem) black (fuel problem) Blue (off timing)
grey(crack/water/vapor)
purple smoke means Pind worked on it.........
Old Oct 10, 2014 | 11:24 PM
[QUOTE=oliver foster;3254237]Popping and smoking white when "getting on it" is a sign of starving for fuel.
Ok makes sense but it's not just thick white smoke it had a bluish color to it as well. I can't see physically any leaks in any of the lines. Best way to test the lines? Or should I just go ahead any replace them anyways. Also how do I test the lift pump?
Old Oct 10, 2014 | 11:31 PM
Old Oct 10, 2014 | 11:38 PM
Pressure testing the lift pump? So I guess from what you and Oliver are saying I don't
have to worry about it being an injector, or injection pump issue?
Old Oct 11, 2014 | 08:10 AM
No worry about the more likely, cheaper problems first.
Get a fuel pressure gauge hooked up after the lift pump, start the truck up, once it is warm, rev it up and check the fuel pressure.
I bet when it is sputtering and smoking the pressure is low or 0.
If so then change lift pump.
If you have lots of fuel pressure, than start looking for air sucking in on the fuel line between the lift pump and the tank.
Old Oct 11, 2014 | 12:15 PM
rrgrassi's Avatar
Blue smoke also can mean burning engine oil. Engine oil can come from many places like worn valve guides, weak turbo oil seals, etc. Luckily it does not automatically mean rings. While you work on it, you can do a compression and leak down test. Good numbers means healthy cumbustion chambers.
Old Oct 11, 2014 | 07:13 PM
We will have to do this. I had spoke to someone from big bad diesel performance and they had said that there is something like a threaded hole or something like that, that I can hook a pressure gauge up to the lift pump? He said should read at 3psi anything lower and the lift pump is bad? Thanks for the help I really appreciate it.
Old Oct 11, 2014 | 07:17 PM
ok so I guess I have a few things to check out. Hopefully it is something simple and cheap. Thanks for the help
Old Oct 12, 2014 | 02:05 AM
rrgrassi's Avatar
As long as the engine has not been abused, and maintainted properly, it usually is simple and inexpensive. Amazing how a 5 cent part can make it look like a $500 problem, and typically, we fix the $500 problem first...
Old Oct 12, 2014 | 02:11 AM
Yup I take care of all my vehicles. Haha yea well said. Have to get some testing done and start checking things off the checklist.
Old Oct 12, 2014 | 02:12 AM
Thanks for the help guys. Will keep you guys posted.
chariotdriver
Dec 11, 2007 10:34 AM
MNorby
14
Apr 20, 2006 12:37 AM
big red psd cc
14
Sep 1, 2004 01:39 PM
94dsl4x4
Jan 24, 2003 08:31 PM
