Exhaust popping and white/blue smoke
Old Oct 18, 2004 | 11:57 PM
MNorby's Avatar
I just got my '97 CTD and have done a few simple mods. The truck is basically stock except for a straight pipe to replace stock muffler and cat and a BHAF. Didn't notice before but after installing the straight pipe put it wide open and around 2200 rpm or so it pops and puffs wite/blue-ish colored smoke. Another buddy of mine has a 96 ctd with dual straight pipes and his does it too. Is this normal or is there a problem? I'm new to this game so just wanna make sure not an injector or fuel problem of sorts. Thanks.
Old Oct 19, 2004 | 01:07 AM
BoostdCTD's Avatar
Maybe it is a bad overflow valve?
If you don't have a gauge symptoms are:
low RPM miss/instability
white smoke
hard starting
engine dies at idle
low power
fuel filter cracking
Old Oct 19, 2004 | 08:24 AM
MDW's Avatar
MDW
BoostdCTD: Boost is right check your fuel pressure first.
Second thing would be to get your timing set, I have seen timing be 6-8* off from the factory.
Old Oct 19, 2004 | 09:11 AM
earl78621's Avatar
mine use to do that. Would make a poping noise and puff a little bit of smoke til it warmed up. My was a timing issue. I figured that out after having to replace the gear housing b/c of the KDP.
Old Oct 19, 2004 | 09:25 AM
MNorby's Avatar
What is the ideal timing? Mine only has 128k miles. Mine does it even if warmed up. It starts great and runs fine. I plan on getting gauges including fuel pressure as soon as $$$ permits but I'll see if I can have a buddy hook up a guage and see what it is currently. What is the ideal fuel psi? Thanks.
Old Oct 19, 2004 | 09:29 AM
earl78621's Avatar
I personally put mine back to stock using the timing pins. Its never done it since.
Old Oct 19, 2004 | 05:41 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
You dont need a fuel pressure gauge on your 12V, pyro and boost are the two important ones. Fuel pressure ussually isnt necessary, if you owned a 24v then its necesity but not the 12v.
Stock timing is stamped on the Engine ID plate and should be somewhere between 12-14*
If it is white smoke with popping odds are it is timing related. Take it into a good performance shop and have them time it to 16* between that and 17* on your pump seem to be the sweet spots. should only cost in the $100-150 ballpark. It does make a difference.
Old Oct 19, 2004 | 06:37 PM
MNorby's Avatar
Sounds good. Can timing be all that hard? I work on HD truck cummins quite a bit so alot of stuff is very similar. Is there a book or instructions and I'm sure I can do it.
Old Oct 19, 2004 | 09:42 PM
torquefan's Avatar
Timing the inline pump can be a real pain. It involves pulling the gear that's pressed onto the tapered pump shaft, turning the engine x degrees, then tightening the gear back onto the shaft. Quite often the shaft can slip in the gear and give you 60 or so degrees. Sometimes it's a 20 minute job, once in a while it takes hours.
Old Oct 19, 2004 | 10:40 PM
BoostdCTD's Avatar
Here is a thing on the overflow valve, maybe it isn't as most people agree it to be a timing issue but none the less.... http://dodgeram.info/tsb/1996/14-07-96.htm
How to set the timing;
http://dodgeram.info/tsb/1994/18-10-94a.htm
Old Oct 20, 2004 | 06:16 PM
SmokinDodge12V's Avatar
If you havent already changed the fuel filter since you got the truck that could be the problem I would check that its easy and cheap.
Old Oct 20, 2004 | 09:10 PM
MNorby's Avatar
my thoughts exactly so I just picked up a new fuel filter yesterday. Haven't had a chance to install it yet though
Old Oct 22, 2004 | 08:38 AM
signature600's Avatar
Mine used to do the same thing.
Changed Timing to 17*
Replaced injectors with Bosch 300's
Replaced Overflow Valve and fuel filters.
NOW, it still does it, but not as bad once warmed up. If you rev it up, it will crackle and pop between 2000-2250, then smooth out, but stilll white smokes clear to the redline.
Sound like a fuel pressure problem? I've never cleaned the pre-filter screen either, could this help?
Thanks Guys,
Chris
Old Apr 19, 2006 | 09:22 PM
Ocmechanx's Avatar
Whatever became of this problem, truck a buddy of mines doin bout the same thing, and I'm not the slickest with 12v's at present.
Old Apr 20, 2006 | 12:37 AM
INJECTOR JACK's Avatar
12 valve
Make sure you don't have any fuel leaks where you good be sucking air in.
John93CTD
Feb 8, 2013 07:41 AM
goatbrain5.9
ABDTR #5
22
Apr 29, 2011 06:14 PM
65fury
Apr 26, 2010 06:59 PM
Dave88LX
Dec 11, 2005 08:18 PM
big red psd cc
14
Sep 1, 2004 01:39 PM
