Wheel nut seat on rim issue-anyone clean up the counterbore?
Old May 27, 2017 | 01:00 PM
samiam4's Avatar
So my steel wheels look sad-
I put new nuts on them and the taper dissapeared. Looking closely at the wheel itself- the tapered 90 degree seat area is nolonger a smooth taper.
Anyone find a grinding stone cheap where they can clean up the wheels- or do I need to just find different ones?? Love to get a set of Alcon, but I've got fairly new 16.5 tires.
M
Old May 27, 2017 | 02:58 PM
Have you tried different wheel nuts, something with a wider taper? I run Dodge Dakota wheel nuts so I can use my 2nd Gen wheel caps, but they have a larger taper and work very well. I also run them on many of my other older mopars.
Old May 27, 2017 | 05:18 PM
death row dave's Avatar
I'm thinking it is a 60 degree tapper , years ago I ran into the same issues with wheels on my 32 Ford . I many still have some tapper repair seats just for this issue . Mine are for 1/2 inch standard tapper . PM me intrested I look them up for you
Old May 29, 2017 | 02:00 PM
u2slow's Avatar
Can you post a pic of the wheel and nut you're using?
It may be that you need a 'bulge' style lugnut so it grabs more of the conical seat area. (Essentially same as what Tcows is saying...)
I would look for something like a countersink reamer with the right angle to dress the wheel holes. Sample:
Amazon Amazon
Old May 30, 2017 | 08:39 AM
samiam4's Avatar
the 13/16 open style show in this picture.
Attached Thumbnails Wheel nut seat on rim issue-anyone clean up the counterbore?-standard-acorn-lug-nuts-1.jpg
Old May 30, 2017 | 01:01 PM
u2slow's Avatar
The stock nuts don't sit right on wheels with larger stud holes. This is the bulged style... the dakota ones are the same idea.
Old Jun 5, 2017 | 09:31 AM
samiam4's Avatar
Thanks- I picked up 3 611-154's this weekend and they seem to be bigger, and the metal is harder. Seems like it will fix the problem. I've got some fuel and hydrulic line grease which is anti-galling. Not as messy as a antiseeze and it's a sticky clear grease. They are exactly the one you've pictured.
Rock has them for $0.76
M
wisconative
May 13, 2013 07:20 AM
Brian.B
Dec 10, 2012 02:14 PM
Clane
Jun 2, 2012 03:31 PM
johnr9q
Jun 4, 2010 12:54 PM
DU.DP.
Mar 18, 2009 12:03 AM
