Lug nut broken, not stud, just nut
Old May 13, 2013 | 02:01 AM
wisconative's Avatar
Being the shade tree hacker that I am, I have always just had shops rotate my tires. After reading tonight, I know better.
Well, today I notice a broken nut on the passanger side front and rear wheels. It's just the nut, or I hope.
Can I just replace the nut?
Should I replace all wheel studs? (1/2 inch? as I think it's still stock)
Where to buy a good set of studs.
At 140K, should I just replace all of them?
If I replace all of the wheel studs, can I do it with the hub still on the axle.
I only ask b/c I am not supposed to work on my truck where I rent, and after spilling 6 quarts of atf this weekend on a 40' stip of the driveway (I forgot to tighten the clamps on sender line when planning for the trans cooler install).
shade tree hacker I know.
But I got the derale pan on, new filter and did the band adjusts. Just wasn't planning on a full atf change
I am half tempted to follow the sticky show how to replace seals and lube everything up.
thanks for helping
Old May 13, 2013 | 07:20 AM
tacoAGGIE's Avatar
if the stud isnt loose or if it doesnt have any stripped threads, I wouldn't bother replacing it. The hub would need to be removed in order to press or drive them out. It involves thaking a few things apart in order to get the wheel hubs off.
Crazy_Farmer
May 23, 2010 06:05 PM
dieselJon
Mar 6, 2008 04:58 PM
74dart
Jul 7, 2007 07:58 PM
Trebor
Sep 14, 2006 04:52 PM
Mikey4X4
Oct 21, 2003 07:26 PM
